Thread: Recommended pH Level
    Apr 2015
    South Central PA
    298
    I was reading the SLAM instructions and it says to adjust pH to 7.2-7.5. The recommended levels section says 7.5-7.8. Is it recommended to raise pH after SLAM or is this an oversight?
    20000 gallon vinyl liner in ground pool
    16' X 34' rectangular diving pool
    Hayward Pro Grid DE Filter
    Hayward 1 hp Super Pump
    TF-100 Test Kit Stenner 45MPHP10
    Jun 2014
    15,255
    Re: Recommended pH Level
    That's correct. After the SLAM, you would test all levels and adjust accordingly.
    38,521
    But, likely the pH will have risen on its own while you are SLAMing ... that is why we recommend lowering it so much at the start.
