Thread: Pool Blaster Catfish Ultra Plus Pole
    May 2013
    Toronto, Canada
    73
    I bought this to replace a Pool Blaster Max. It comes with a pole which is not convenient for us. Our two universal poles fit the Catfish but the fit is so tight that it is a real pain getting the pole off. They worked perfectly with our Pool Blaster Max. Is there a pool pole that has a slightly larger inner diameter or some trick to make removing the pole easier?
    Philip
    12.5x21.5x52" on-ground 29" below ground (6000 gallons water), .85 HP Hayward SP26115VSP , Hayward XStream 100 sq.ft. cartridge filter, Hayward AquaRite salt system, 160 sqft of Aquatherm solar panels on 12' high flat roof 25' away from pump, Goldline auto controller for solar, Heat Pump, May->October @77+ in Toronto, Pool Python.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Pool Blaster Catfish Ultra Plus Pole
    How about taking some sandpaper to the pool blaster and reduce the diameter a few thousandths of an inch?
    May 2013
    Toronto, Canada
    73
    That's a great idea. The thing that really makes it hard to remove is the tight fit, especially the two plastic knobs that are pushed in and then go into the holes in the pole. Will try the sandpaper tomorrow.
    Philip
