Thread: Algaecide question
    Jun 2015
    Ottawa/Ontario
    340
    Algaecide question
    Hi all
    Question on when and whether to add algaecide. We closed properly last year, and I kept the winter cover clean, etc. This spring when we pulled back the tarp, the water was very clear - I removed the debris, shocked the pool, and am now topping up my CYA as the pumps run. But no algaecide - any thoughts on this? Do I need to bother?
    68,000litre, IG vinyl, LorentzPS 600 Solar Pump & 1/2 HP Tristar, Sandfilter, Aquarite T-15 SWG
    20000 gallon, IG, SWG, Sand Filter, Hayward 1/2HP + Lorentz direct solsr PV pump
    Donldson's Avatar
    NW Ohio
    2,904
    Re: Algaecide question
    If you are keeping your FC above the minimum for your CYA level then your pool will remain clear with no need for algaecide.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Algaecide can cause problems with some of the ingredients, namely metals. Following the TFP method of care and maintenance will ensure that you never need to use an algaecide. Even if you do get a little "green" a simple SLAM will clear that up.
    Solar Blanket, Well Water, Borax Added. 68
    Jun 2015
    Ottawa/Ontario
    340
    Thanks all!
