Results 1 to 15 of 15
Thread: Found my air leak. Now I need to know, fix or replace the pump
    May 2016
    Corcoran, CA
    27
    Finally get the pool cleaned, filled and turn on the pump. I notice that I have air coming through the returns. I found the leak after I turned off the motor.
    Best i can tell it is leaking from where the filter basket is attached to the rest of the pump.
    Is there a seal inside here that can be causing this? Looking for advice before i tear anything apart.
    New owner of old pool
    30K GAL, IG plaster, max-e-pro xf 1.5hp motor with 3/4hp booster,
    Triton FNS Plus 60 D.E. filter, sweeper out of commission, built 8-1989
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,750
    Re: Found my air leak. Now I need to know, fix or replace the pump
    There is almost certainly a gasket or o-ring there but it is always better to know make and model of the pump and find a source for spare parts before taking anything apart.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    May 2016
    Corcoran, CA
    27
    The only thing I could make out from that was the patent number, which gave me Sta Rite Industries.
    If it is original to the pool, then it is from 1989.
    Here is another angle of it:
    Mike Hawk's Avatar
    Oct 2014
    Tulsa OK
    51
    I'd start going thru each Sta-Right pump on this link to find which one is yours
    Pool Pump Parts - INYOPools.com
    2007 Gunite 15k Pump: Whisperflo Motor: B2983 2spd 2.2/0.28 SFHP Sand Filter: TR100 SWG: Aqua Rite T15 Timer: PF1102T w/ redneck SPDT toggle switch Vacuum: Milliard 19" manual / PoolCleaner 2X auto
    Jun 2014
    Houston
    110
    If the gasket has blown and let water back into the motor then you may also be looking at bearing issues with the motor further down the line as well.
    30 year old, 17,000 gallon pool (w/spa), IG, Plaster, Pentair Triton II TR-100 600#Sand Filter, Pentair Superflo 340043 1.5 Hp pump
    May 2016
    Corcoran, CA
    27
    Thank you Mike for that link. Mine appears to be either the starite dura-glas or max-e-glas. I ordered new shaft seal and gaskets for it. They should arrive Monday. I'll take it apart then and hope nothing else is wrong with it. I will be replacing the motor and relocating the plumbing this winter, so I just hope it gets through the summer.
    Apr 2015
    tucson, arizona
    1,107
    That is a dura-glas pump. It appears the leak is at the suction gasket. By removing the four bolts and carefully pulling apart you will find either a rubber gasket or paper. Need to remove and replace with a new rubber one, part # C20-123. This pump was is made by Sta-Rite now owned by Pentair.
    May 2016
    Houston
    5
    I agree. I had an issue like this a couple of years ago.
    May 2016
    Corcoran, CA
    27
    Good morning all. In preparation for my new seals and gaskets arriving today, I pulled the pump to the garage to get it cleaned and prepped. While attempting to remove the impeller, I broke something off.
    Not sure what it is exactly, but hoping I can fix it with your help.
    Inside cap of motor.
    The piece I broke.
    Shaft seal
    Impeller, top and bottom
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    That piece is called the centrifugal switch. It's what switches the capacitor out of the circuit once the motor gets up to speed, Hope that helps.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jul 2015
    Gilbert,AZ.
    123
    the trap body, or trap, holds the basket, and pump lid, and has the 1.5 '' threaded inlet in front.
    the trap then connects to the tank body, where the bad gasket is, and the 4 bolts secure the trap to the tank, while it appears that by removing the 4 bolts you can just slide a new gasket in between the trap and tank, you cant, due to an extension of the tank body that you cant see that extends into the trap about 1/2'' or so, so you have to seprate the trap from the tank 1/2'' or so to get the new gasket over it,
    May 2016
    Corcoran, CA
    27
    Problem soon to be fixed. Picked up new motors/pump just now. 1.5hp uprated by 1.47 and 1hp booster.
    Forgot to add that I got them for 75 a piece.
    May 2016
    Corcoran, CA
    27
    One more question and I think I'll be done. When hooking up the electric, does it matter which black wire goes on L1 and L2? I'm not much of a 220 guy.
    Oct 2015
    Katy/Texas
    411
    AC is not polarity sensitive.
    In ground, 14,000 gallon, white plaster, unheated, stone waterfall, DE Filter, Rainbow 320 Cl, Polaris 3900, FloVis flow meter, F100 test kit, Circupool RJ30+ SWG, Circupool VJ1/Speck Badu EcoM3V variable speed pump.
    May 2016
    Corcoran, CA
    27
    Thanks. Fresh wires and connectors just make more sense to me with a newer motor. Old wires were cracking they were so old. Hoping to have to pump running tonight after pvp glue has time to set.
