Results 1 to 7 of 7
Thread: Lot of Acid
    Jun 2015
    Houston, Tx
    19
    Lot of Acid
    So this is my second year following TFP protocol. Started both years with a SLAM and everything has been going well.
    I have noticed that this year I am having to use a lot more acid than last year. I think this may be due to the fact that I had a slow leak last year that I did not know about and have since fixed. I guess the water my autofill was adding was just the right acidity to keep the pH in balance.
    Since this is the first year that I have had to use significant amounts of acid to balance my pH I just want to make sure I am not missing something even though my numbers looks good. For the past 6 weeks or so I have had to add 32 oz of acid every 7-10 days. My pool is large (29000 gallons) but I wanted to make sure this wasn't way out of the norm.
    Thanks
    Current numbers
    FC 4
    CC 0
    CYA 35
    ph 7.5
    TA 120
    CH 350
    In ground 30,000 gallon rectangular plaster/pebble pool, hot tub with blower, 2 HP Pentair WisperFlo Single Speed Pump, 420 Pentair Clean and Clear Plus Cartridge Filter, Pentair Rainbow 320 Chlorinator, Easy Touch Control System, Pentair 400K BTU heater, Interfab G Force Slide with dedicated 1 HP pump, Travertine Decking, CoverStar automatic pool cover
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,074
    Re: Lot of Acid
    A slightly lower TA will probably help. Keep adding acid and it will go down over time. What are you targeting for pH when you add acid?
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    38,303
    Re: Lot of Acid
    Your TA is a little high, so that drives the pH up.
    Do you have a spill over from the spa to the pool? That causes aeration and the pH to rise.
    Are you using the tablets in the Rainbow? I hope not, but those are acidic, so usually low pH is more of a problem.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,013
    Re: Lot of Acid
    I'd call that low. I use that much on a pool half your size. Part of the problem is the high TA. Once you get it driven down to 70ish or less, the pH should stay even more stable. There's no reason to rush, just knock pH down to 7.2 every week and TA will come down.
    Aug 2010
    Dallas, TX
    4,052
    Re: Lot of Acid
    I add a gallon a week currently, but we will see if my new balance will help. My TA is currently 80 before anyone asks.
    Jun 2015
    Houston, Tx
    19
    Re: Lot of Acid
    Quote Originally Posted by Mr Bruce View Post
    Usually targeting 7.5
    No tablets.
    Small spillover with hot tub (maybe an inch), but I am getting more aeration from the water slide.
    Aeration should drive my TA down, correct?
    Aug 2010
    Dallas, TX
    4,052
    Re: Lot of Acid
    Adding acid drives down TA. Aeration takes pH back up. Rinse, repeat.
