Thread: GVA-24 Actuator help please!
    rbinn's Avatar
    May 2015
    Nanaimo BC
    85
    Hi Guys,
    I'm hoping someone may have run into this before. My pump is scheduled to come on from 8:30 am to 8:30 pm. This morning the pump turned on and after about 15 minutes the actuator began to turn to send the water to the solar panels. It looks like it got about 1/2 way between then stopped with a high pitched whine. I pulled the top of the actuator off and the round motor part was really hot. I could turn the valve manually so I don't think thats the problem. What would be the next step for trouble shooting?
    The whine is on both 1 and 2 on the little switch.
    Any thoughts would be appreciated. This setup has been wonderful since I dialed it in...
    Rob
    9 x 18 Hydro Force AGP, Aqua Pro AP ASFAL 75 pump and sand filter, Hayward Skimmer, Raypak 106A propane heater, Sunquest Solar Panels, Pentair Rainbow test kit.
    rbinn's Avatar
    May 2015
    Nanaimo BC
    85
    Re: GVA-24 Actuator help please!
    Looks like it is the motor for sure. Took it off gave it power and it is seized both ways. I have ordered a new one but are there replacement motors available so I can repair this and have a s a backup?
