Results 1 to 8 of 8
Thread: Adding borax to adjust ph of initial fill
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,750
    I will be filling my pool with well water. My well water has a low ph of 5.8 right from the well. I actually have a calcite filter to raise the ph of the water in the house which I will be bypassing when I fill the pool. My question is since I will have known acidic water to start with and want to add borates to the pool can I just use the borax to raise the ph. As opposed to raising the ph with soda ash or other similar chemical then doing the borax and MA dance after that.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    38,251
    Re: Adding borax to adjust ph of initial fill
    You need to be a little careful because the act of filling is going to aerate the water which could bring the ph up some. But your plan to use borax is also acceptable just keep track of how much you use you can estimate your borate level.
    Jun 2014
    15,008
    From our Recommended Chemicals page:
    PH can be raised in three ways: borax, soda ash, and aeration. Borax is usually the best choice. Borax raises the PH and also raises the TA level just a little. If your TA level is low soda ash will raise both the PH and TA levels. If your TA level is high, aeration is best as it will not raise the TA level at all. However, aeration is rather slow compared to the other two.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,750
    I've read that page too ... oops brain fart
    Chuck-
    38,251
    What is your fill water TA?
    Need to be sure that is reasonable before adding too many borates.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,750
    I have a TF test kit already maybe I will run some tests on my well water just to play with it. I wont know for sure where the TA will end up till after the pool gets filled tho. I've been trying to get as educated as I can on the chemistry before I need to start doing it. Also the 4 weeks it took my town to give me a permit has left me getting antsy to be done with this project. The weather in the northeast is finally coming around.
    Chuck-
    38,251
    The TA should not really change while you are filling, the pH will come up some though.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,750
    It has been a while since I've tested the performance of my acid neutralizer and water softener on my well all the more reason to play with some chemistry.
    Chuck-
