Thread: Suction side air leak
    Jun 2015
    Tybee Island, GA
    1
    I have an elusive air leak. I have changed all fittings from the pump suction inlet to the point where the suction pipe goes underground back to the skimmer. New skimmer weir, all new els, and couplings and gaskets with the exception of the pot lid and gasket which i have on order. If the new lid and gasket do not solve the problem, any ideas on what i might try next prior to digging up pipes and breaking up concrete?
    In case its important, the wall fitting in the deep end where the water returns to the pool has lots of air bubbles while the one on the shallow end does not.
    C Phillips
    Jun 2014
    15,221
    Re: Suction side air leak
    Hi Carroll and welcome to TFP! To help us better, can you please add your pool info to your signature by going to the top of the TFP web page (just under the Pool School button) and select "SETTINGS". On the next page look to the left for a menu bar that says, “MY SETTINGS” and go to "EDIT SIGNATURE" to enter your pool and equipment info there. It will help us later. This link may also help you: Pool School - Read This BEFORE You Post.
    We're going to need some of that info in an effort to try and get you some good guidance. As for the air bubbles from one return and not the other ... I don't see that as a huge thing in itself yet. Your plumbing may dictate where air can come out when returns are plumbed on the same line. Mine is that way, so the first returns to have air comes across them are the ones spitting-out the air bubbles. But we'll try to help you as soon as we know more about your equipment.
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    483
    Lid gasket is most likely the culprit *Crosses fingers*.
    Oh and I had bubbles coming out one return last year and replacing the spider gasket fixed it.
    SLAM * Chlorine/CYA Chart * Pool Math * Pool School
    17.5k gal IG Fiberglass, Triton II TR60 Sand Filter, Jacuzzi Magum Force Pump 1.5 hp, 3/4 hp booster, Polaris 280, TF-100 Test Kit with Speed Stir
