Thread: Should I drop Mineral Springs?
    Our pool is "Mineral Springs", and startup each year costs several hundred dollars, and we have a maintenance bag every week on top of that. We also use regular shock and muratic acid as needed per their water analysis. I'm starting to think it's a premium product that our pool company pushes for higher sales and margins.
    He said that the Mineral Springs includes optimizer, scale inhibitor, salt, muratic acid, and cyanuric acid, and if we didn't use Mineral Springs, we'd need to add those things individually.
    Do you think I could drop the Mineral Springs products, and instead just use regular pool salt, plus weekly shock, and muriatic acid as needed? I currently do those things already as needed based on test strips. I also vary the salt cell % as needed during the summer months to maintain appropriate chlorine levels.
    We've never had a problem with algae or maintaining the chemistry, even when we strayed from the Mineral Springs bags for most of last summer.
    18,000 plaster in-ground pool and spa. Pentair Inteliflo VS filter pump (replaced 2014). Raypak 260k heater (replaced 2016). AquaPure salt cell (replaced 2015), Aqualink RS controller + 2 JVAs. Jandy DEL60 filter. Polaris 280 with booster pump.
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    Re: Should I drop Mineral Springs?
    Drop it like a bad habit.
    Check out this article:
    On top of that, you don't need to shock on any regular basis as long as you are keeping your FC within range.
    We also don't recommend test strips as they are pretty unreliable. Grab a TF100 or K2006 kit.
    Helpful Links: Pool Chemistry 101 - Recommended Levels - Recommended Chemicals - FC/CYA Chart - SLAM Instructions - Pool Math
    Test Kits:
    TF-100 - Taylor K2006 - SpeedStir Upgrade - Taylor K-1766 Salt Test
    My Pool:
    28k IG built May 2015 - Autopilot SWG - Pentair VS Pump/DE Filter/Heat Pump
    Aug 2010
    Dallas, TX
    4,052
    I am assuming you are using "Renewal"
    sodium hydrogensulphate
    7681-38-1
    15 - 35 %
    boric acid
    10043-35-3
    2 - 13 %
    sodium sulphate
    7757-82-6
    < 5 %
    aluminium sulfate
    10043-01-3
    1 - 7 %
    Phosphonic acid, reaction products with maleic anhydride, sodium salts
    180513-31-9
    0.1 - 3 %
    cyanuric acid (Dust)
    108-80-5
    0.1 - 3 %
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    you dont need it, and you dont want it! you have a saltwater system, thats all you need to use. i cant believe they have you doing other stuff, oh wait, i know why
    get your salt cell dialed in and all you should need to do is possibly add a little muriatic acid every once in a while to lower your pH.
    CYA and Salt doesnt decrease so there is no need to be adding that every week, and you shouldnt
    you just need to get a test kit, not strips. Get the TF-100 it will last you a long time. once you have it, you will determine your stabilizer (CYA) levels and base your chlroine levels on that. as the water warms up, you just increase the pump run time or salt generating % to increase to compensate for additional losses.
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Yep, that's what I thought. Thank you for your responses and confirmation, I'm going to pick up a proper test kit and study up in the pool school.
    38,540
    Sounds like a plan.
    Too bad we did not have this discussion 3 years ago when you joined
