Results 1 to 7 of 7
Thread: TFP Glycerin filled pressure gauge
    Apr 2016
    Springfield Ohio
    11
    I need a new gauge and noticed these on the website. I live in ohio and noticed they are rated to -4 degrees. Does anyone in the northern states have one of these gauges? Just not sure if will make it through the winter. I quess if all else fails I could just take it inside each winter and reinstall in the spring.
    18x36 inground vinyl 27000 gal approx. Hayward heatpump heater. Hayward 1 hp super pump single speed. Hayward sand filter. Maytronics dolphin robotic cleaner. TFP 100
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: TFP Glycerin filled pressure gauge
    I *ahem* intentionally left mine outside this winter for testing. Yeah... testing. Still works this spring. I would recommend bringing it inside though.
    Isolated Spa - 345 Gallons
    Apr 2016
    Springfield Ohio
    11
    Thanks for the quick reply. As I was typing the question it dawned on me to just bring it in in the winter. I normally would just leave the old one in during the winter. Im sure your winters are a tad more brutal than mine.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    If your filter isn't under roof, be sure to plug the hole when you remove the gauge to keep rain water out.
    Apr 2016
    Springfield Ohio
    11
    Quote Originally Posted by JohnT View Post
    Good advice as I would not have done that. Ill plug it with the broken gauge.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Wow! If ya'll are worried about stuff rated for -4 surviving winter! Ewwww
    wjr75's Avatar
    Jun 2013
    IL
    836
    Ya it gets to -20 F up here. I have had broken valves even after the winterizing.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
