Thread: Removing Dried Grout from Pool Tile and Coping
    Mar 2016
    San Antonio , TX
    5
    Just did a pool remodel and upgrade. The workers did not wipe up the excess tile grout very well while it was still wet. I have many areas on the tile faces and coping edges where there is hard dried on grout. Tried to remove with a wire brush, but didn't work very well as the dried grout is that hard and was afraid of scratching the coping edges (travertine). Thought about using a muratic acid solution, but thinking only on the tile as I'm guessing that it should not be used on the travertine coping edges. Any thoughts?
    Apr 2013
    Sacramento, CA
    2,769
    Re: Removing Dried Grout from Pool Tile and Coping
    First I call the tile contractor and have him come back and fix the problem.
