Thread: Built in Solar Cover (video)
    Feb 2012
    Maryland
    400
    I hate have the big ugly roll of solar cover always sitting around, so we went in search of a way to hide it. We were building this raised deck as a jumping platform and had an idea to hide it under that. I found a guy online (Michael Wade) who sent me designs he had on his build and I modified them a bit and wow it came out awesome!
    The solar reel is bolted to an aluminum frame. I have two (weather rated) electric actuators mounted to push the platform up and down. The actuators are triggered with rocker switches and it is all run with a low voltage 12V DC power supply. The power supply is mounted in the house, run out and under the deck. These actuators are actually designed for raising hatches on the motor compartment on large boats. Some final work still needs done to clean this all up, but this is the season constructions ends!!
    DIY 18x36 IG Vinyl Rectangle with 2 foot radius; Steel Walls. 8' steps w/t 2 step jets; 2 MD, 1 Skimmer, 2 returns; Hayward Pro Series 24 Inch 300# Sand Pool ; Hayward color logic 4.0 LED light; 2" PVC pipe 4 Jandy Valves, Hayward PL-P-4, SWCG
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Built in Solar Cover (video)
    OK, that is really awesome great job...
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,822
    That is a great solution - well implemented!
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
