Thread: Thoughts on my M500 after a couple weeks
    Apr 2016
    Kershaw, South Carolina
    80
    So I've had my Dolphin M500 for several weeks now, All I can say is YAY!! cleanest pool on the block.. ok, so I don't live on a block.. so what?
    The M500 does an outstanding job of cleaning my pool, gets everything on the floor, first step and sometimes even the second step. Does not get my waterline most of the time but that's more due to my pool design than anything. I have a pair of "shelves" running the perimeter of my pool (fiberglass) to allow someone to get out anywhere they want to around the edge.
    The remote still seems to be a mystery to me, while I CAN drive the bot around if I want(normally drive it close to me for removal) I does not seem to change its functions when I try, regardless what I plug in it just does the normal 2.5 hr cleaning.
    Top filters are a breeze to clean! Also, using the less "fine" filters allows it to climb better..I'm guessing due to more suction.
    Lastly, great strong caddy, easy to wheel around, and pull up onto the higher concrete to where I store it.
    All in all, a great pool cleaner.. if I were to do it again the only thing I "might" do different would be to get the M400 instead, pretty much the same thing minus remote.
    Pool... IG 16,500 gal fiberglass, Pentair Sand Dollar filter, Pentair Superflow 1 speed pump, Pentair control box, Installed 4/2015, Test strips! HA! ;-), SWG, hot tub (spa) freestanding on deck, fill it from my well, sometimes through my water softener. Oh, and a HydroNet radio control leaf skimmer boat! AND... A brand spankin new Dolphin M500 robot! ;-)
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Thoughts on my M500 after a couple weeks
    So, it doesn't run longer when you select one of the different clocks at the top of the remote screen?
    Essential Links:
    Apr 2016
    80
    It does not.. just tried it again yesterday, put in the short program and 2 1/2 hours later it shut off!
    poolhound's Avatar
    May 2008
    Elgin, SC
    54
    Where did you buy your Dolphin and did you like the service? I'm looking for a dealer close to me (us).
    24000gal IG, VL, 1.5 HP, Pentair 60/60D Sand 325#, BBB, Stenner45MHP2 (Replaced Liquidator), Dolphin M400
    Apr 2016
    80
    Quote Originally Posted by poolhound View Post
    Jack Olivers pool spa and patio
    3303
    Forest dr Columbia
    They did fine and dandy, lowest price I could find.. there only service to me was selling it to me seemed nice enough though.
