Evaporation question
I read somewhere that evaporation increases with water temperature. But what if the water is cold, but the air even colder. Last night we seem to have lost a quarter of an inch. The water temperature is 55 and the temperature got down to 36 overnight. Would you expect a lot of evaporation in those conditions? I tried the bucket test and I 'think' the bucket lost the same amount of water. I'm just questioning the validity of the test because the evaporation seems somewhat high to me.
A 20 degree difference between the water and the air, and considering cold air can hold less moisture than warmer air, could cause evaporation. I would think that the key will be to see if it continues to lose that much water regularly - then you can start worrying about a leak. :)
It is the difference between the water and air vapor pressures that drives evaporation. So if humidity is lower than 100%, the water and air temperatures can be exactly the same and evaporation still occurs.
For those temperatures ranges and humidity, 1/4" is a bit high but if you don't have much of a wind break (e.g. trees, buildings, etc) around the pool, it is possible.
