Results 1 to 12 of 12
Thread: Pentair Mastertemp 250 Warranty
    Jul 2013
    Grand Rapids, Michigan
    55
    I have a Pentair Mastertemp 250 that is now entering it's 4th pool season. I went out last night to find the service light on and water leaking from underneath. I'm trying to find what the warranty is on it but all I can find is referencing some card I don't have. Does anyone have any idea what the warranty is on these? I will make a difference who I call for service. I included a picture just in case someone can suggest something else I should check. Thanks.
    23,200 gallon in ground pool, Vinyl Liner, Salt Water, Variable Speed Pump Intelliflow 3hp/1.32SF/3.96 SFHP, Filter Pentair FNS PLus DE FNSP36, Heater Pentair Mastertemp 250, SWG Jandy APURE35PLG, TF-100 Test Kit
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Pentair Mastertemp 250 Warranty
    Looks like something corroded the inside but maybe its fixable.... Have you always had an SWG? cuz I would suspect low ph as a culprit. You sure the drain plug is set properly?
    Most heaters have a one-year warranty, 2 at most, and they are predicated on PRISTINE chemistry balance....
    Jul 2013
    55
    Yes I have had a SWG from day 1 and the PH has always been right in the appropriate range. Too bad about the warranty. I was hoping it would have been longer. I'll reach out to one of the service teams. Thank you for your help.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    When you got that heater (4 years ago) the warranty i think was just one year. If you bought it yesterday, it would be two, three if you bought all Pentair equipment. Either way, at 4 seasons, you are out of warranty.
    You will need to take the jacket off the heater, and remove one of the lower flange bolts to check for water. Or, if you can see water pouring or dripping from the blower inlet, both the blower, and the heat exchanger are done. There is a kit for replacing the exchanger, blower is extra.
    Factory Warranty Station for:
    11,969
    Quote Originally Posted by Pool Clown View Post
    You will need to take the jacket off the heater, and remove one of the lower flange bolts to check for water. Or, if you can see water pouring or dripping from the blower inlet, both the blower, and the heat exchange are done. There is a kit for replacing the exchanger, blower is extra.
    We need a "like" button like they have on FB. Glad to see PC is still around!
    ps0303's Avatar
    Jul 2011
    FL
    3,708
    If you have water in the can, scrap the unit and get something better. If you maintained your chemicals like you say, this unit should have lasted way more than 4 years.
    Did you check to see if the pressure relief valve was leaking? If your unit was installed with one.
    Paul
    http://www.gastekservice.com If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Check out some videos on my YouTube channel - http://www.youtube.com/c/Gastekservices
    Jul 2013
    55
    UPDATE - Had a service tech out and they are telling me it's a cracked heat exchanger. How exactly would that happen on a 3 year old heater?
    ps0303's Avatar
    Jul 2011
    FL
    3,708
    How did they determine it was cracked? Did they open up the can and look?
    Scrap it and get a Raypak.
    Paul
    Jul 2013
    55
    They did open it up and said it was cracked. At 3 years old I'm not ready to scrap it.
    Can this be caused by water left in the heater in the fall?
    ps0303's Avatar
    Jul 2011
    FL
    3,708
    Quote Originally Posted by Aspfam View Post
    Yes if you left water in it and it froze it could crack the heat exchanger.
    That will be a costly repair.
    Paul
    Jul 2013
    55
    Am I better off repairing it or replacing the heater based on the cost? If replacing it what are people finding to be the most reliable brand?
    ps0303's Avatar
    Jul 2011
    FL
    3,708
    A new heat exchanger is probably going to run you about $700 +/- plus the labor. I guess total around $1000.
    Raypak.
    Paul
