Thread: How many gallons of beach for SLAM, 45k pool?
    May 2016
    Nesbit, MS
    5
    Wondering if anyone may estimate the number of gallons of regular (8-9% sodium hypochlorite) bleach I should have on hand to SLAM A 45,000 gallon in ground? TC is 3, FC is .5.
    45,000 gallon in-ground large T, vinyl liner, Jacuzzi 1.5 hp magnum pump, Hayward 24" 300lb sand filter.
    Jun 2014
    15,059
    Re: How many gallons of beach for SLAM, 45k pool?
    Hello and welcome to TFP! To be honest, it's impossible to answer your question at the moment since we have no idea how long a SLAM will take to clear your water. We also do not know what your current CYA reading is which drives how high your FC level should be. So if you could provide us with a good CYA reading from your TF-100 or Taylor K-2006, we can give you some ideas. Of, you can use the Poolmath Calculator (link below) which is what we use anyways. Depending upon the condition of your water, a SLAM can easily last anywhere from 7-14 days. "Swamps" can last a bit longer.
    Nice to have you with us.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,581
    As a starting point..........using Poolmath...........one gallons of 8.25% bleach will raise your FC by 1.9.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Welcome to TFP
    What test kit do you have, If you can post up your numbers it would help us give you some recommendations
    Aug 2010
    Dallas, TX
    4,052
    A whole bunch, look at my sig line and you'll see how I know.
    One thing, SLAM time is variable, so there is no way to put a number to how much bleach it will take.
    We need a full set of test numbers, especially CYA.
