Thread: Just Curious - Higher CYA with SWG
    May 2015
    Wichita KS
    29
    I am just curious (I'm geeky that way always wanting to understand something) WHY is it recommended that your CYA is higher for a SWG pool than one maintained with bleach?
    My SWG manual says to maintain at 30, whereas TFP recommends 80? I brought mine up to 60, but just scared to go higher after all the posts I've read of CYA levels being too high.
    If someone could explain it to me, then I might feel more comfortable adding the extra 20.
    Coleman 18'x48' AGP
    Intex Krystal Clear Sand Filter Pump 2800GPH
    Intex SWG
    **Under Construction** :)
    38,371
    Re: Just Curious - Higher CYA with SWG
    Because the SWG adds chlorine slowly and the higher CYA level better protects it from the sun. You actually end up needing to add fewer ppm of FC daily when the CYA is higher, so you SWG does not have to work as hard and should last a little longer.
    May 2015
    Wichita KS
    29
    Thanks! That makes perfect sense. I will add more CYA
    Coleman 18'x48' AGP
    Intex SWG
    38,371
    The higher the CYA, the less chlorine you need to add daily. But, the risk is if you have to slam and then the FC level you have to maintain is quite high.
