Results 1 to 11 of 11
Thread: Is It Just Me, Or Can You Simply Eyeball FC After a While
    MarkTX's Avatar
    Nov 2015
    Cypress, TX
    337
    Hello,
    Been reading on here for 7 months, and we started our new (and first) pool with TFP 3 months ago. Fortunately, we have had no chemistry problems, and we have not been pool-stored. Rather, we have had the clearest pool water I have ever seen. But I test (esp FC) almost daily. Lately, I have noticed that I can kind of discern FC just by looking at the water. Is that the normal case? Or am I imagining it? Because eyeballing is much more convenient. And I think if eyeballing your FC is possible, it would be a strong testament for the TFP method.
    30,000 gal free-form IG w/ spa, PebbleSheen Blue Surf, Pentair cartridge filter, Pentair 3 HP Intelliflo, extra pump that is way over-sized for weeping moss rocks, Dolphin Oasis Z5, municipal water, all built Jan-Feb 2016. TF-100, SpeedStir, Liquidator 3/8", borates. My build thread http://www.troublefreepool.com/threa...-in-Cypress-TX
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Is It Just Me, Or Can You Simply Eyeball FC After a While
    I can eyeball when there is not enough FC or none at all
    Aug 2014
    Northern IL
    4,615
    Yup. But with a new pool, I would err on the side of over-testing.
    Jun 2014
    15,212
    Man - you guys are on a whole other level of TFP zen ...."at one with the water" grasshopper. Woo. I still test.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,050
    I'm afraid I haven't reached that point yet with the chlorine. But I can tell by the dullness of the reflection off the surface if the pH is too high. Could be that 4-figure CH...
    Aug 2014
    Northern IL
    4,615
    To each his own pool. And until you REALLY know YOUR pool: test, test, test. OHMMMM....
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    I can't even eyeball the OTO chlorine test.
    Helpful Links: Pool Chemistry 101 - Recommended Levels - Recommended Chemicals - FC/CYA Chart - SLAM Instructions - Pool Math
    Test Kits:
    TF-100 - Taylor K2006 - SpeedStir Upgrade - Taylor K-1766 Salt Test
    My Pool:
    28k IG built May 2015 - Autopilot SWG - Pentair VS Pump/DE Filter/Heat Pump
    Aug 2010
    Dallas, TX
    4,052
    I can tell the moment I walk outside if something is off. Not just by the appearance but by the smell. When everything is right, my pool has no smell at all. If I smell anything, I know something has gone wrong.
    If you are using a LQ, you should be able to get away with weekly testing if you have it tweaked.
    jrs_diesel's Avatar
    Aug 2014
    League City, TX
    215
    By eyeball I can tell if there have been a lot of people in the pool since the water will be slightly cloudy.
    By smell, I can't really smell it unless my nose is right near the water, and only then I might catch a slight whiff of chlorine.
    Getting to know my chemistry, now that makes it easy. I've gotten to the point of knowing my normal chemical levels (CH, CYA, TA) and water temperature, plus the days weather will give me a good idea of how much liquid chlorine I need to add for that day.
    J.R.
    20K IG gunnite pool
    2HP Hayward single speed pump
    Cartridge filter
    poolnewbies5874's Avatar
    Aug 2015
    SW Ohio
    124
    If it's sunny out, I can tell if it needs chlorine by how shiny and sparkly the water is but I'm not good enough to know how much it needs.... Yet😉
    12,000 gallon Blue Hawaiian 'Hamilton' fiberglass IG 15x34 freeform, Pebble Beach finish, Pentair Clean & Clear 100 filter cartridge, Pentair SuperFlo 1.5HP pump, Stenner pump, Raypak 266k heater
    8/2015 pool build photos TFT-100 test kit
    Mar 2016
    Wimberley, TX
    51
    Our previous home we had the pool for over 16 years. After about 5 years I could tell almost immediately if something was off. 99% of the time it was CL or PH were low, the water just wouldn't have that sparkle to it . Our new pool, we've only had for 8 months and I'm still learning and testing every day.
    15K Gallon, IG Pebble Sheen pool with SPA (8/15/2015). Wrap around stone waterfall, spill over spa and bubbler on tanning shelf. Pentair FNS Plus 60 DE filter, Pentair Whisper Flo for filter circulation and Pentair Intelliflo for water features. Pressure side pentair sweeper, Pentair heater and Rainbow 320 Chlorinator (just use to keep CYA in check), Haas Liquidator and all powered by a Pentair Intellitouch system. K-2006 test kit.
