Results 1 to 7 of 7
Thread: Starting to green
    Apr 2016
    Corpus Christi
    2
    Starting to green
    I just recently switched to the bbb treatment a couple weeks ago. I don't have the test kit y'all (I'm texan) recommend, so I took it to a place and had it tested. Here are the results:
    FC 5.8
    Total chlorine 6.1
    CC 0.3
    pH 7.7
    CH 283
    TA 79
    CYA 95
    copper 0
    Iron 0
    Can you guide me as to what I should do?
    6k AG/ Jacuzzi Sand filter/Waterway pump HP 1.5 SPL
    Hot and humid weather most of the time/ partially shaded with banyan trees & jasmine debris
    38,275
    Re: Starting to green
    Welcome to TFP!!!
    About the only thing you can do in invest in one of the Recommended Test Kits and post up those numbers ... because we have found pool store testing to repeatedly be so inaccurate, providing suggestions based on them is a bad idea.
    If you want me to turn a blind eye to the source of those numbers and offer my thoughts ...
    Your FC is too low for your overly high CYA. You need to replace at least half the water to lower the CYA to a reasonable level and then follow the ShockLevelAndMAINTAIN Process (which BTW, requires the FAS-DPD chlorine test only found in the recommended test kits )
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Are you sure your pool only holds 6,000 gallons?
    Apr 2016
    Corpus Christi
    2
    Welcome to TFP!!!
    So I replaced 50% of the water with city water and took a sample to Leslie's (I will purchase a test kit, but this is what I have for now)
    FC 0
    CH 170
    CYA 100
    TA 80
    pH 7.6
    No metals
    Phosphate 200 (which I know you said not to worry about,but it resulted...I'm just reporting it)
    The pool is looking swampy.
    I'm not sure which parameter to adjust first.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    You need a test kit. Period.
    Pool store testing is useless! Look at your numbers. Your CYA was at 95, you replaced half the water, and now the CYA is 100? Tap water has zero CYA. There's no way the CYA can climb unless one or both of the CYA tests are wrong.
    You can ask all the questions you want, but the answer is always going to come back to accurate test results that you just don't have.
    Jun 2015
    Glendale, AZ
    156
    If you did not add any CYA, then your 1st test results were wrong or your 2nd tests are wrong, or both tests are wrong. I would not trust any of the test results, if it were me I would try to get one of the recommended test kits ASAP so you know exactly what to do.
    Valley of the Sun, Arizona.....10k gunite/pebble (Re-surface March 2015) w/in floor Caretaker 99 cleaning heads -- Pentair FNS 60 DE filter -- Pentair IntelliFlo Variable Speed for pool -- Pentair Wisperflo 1 HP for boulder waterfall...Taylor K-2006 & Taylor K-2006C kits
    11,969
    If your pool is really only 6,000 gallons you may want to just dump and start over.... 6,000 gallons for an AG pool? Is this an Intex or similar type pool?
