Page 1 of 4 1234 LastLast
Results 1 to 20 of 66
Thread: Newb that needs help.
    May 2016
    Duncan, Ok
    89
    Hello all and thanks in advance for the help. We purchased our house during the winter and the pool hadn't been opened in 5 years per the realtor. It's a beautiful pool and the kids really enjoy it. Ingound, concrete/plaster 38' by 22' bean shaped pool goes from 4' 9' deep.
    Question is:
    I've got these dark shades in the bottom and dark spots forming. Pool was drained, pressure and acid washed about 10 days ago. Is this something to be concerned with?
    FC- 5
    Ph- 7.5
    CYA- non existent
    TA-140
    TH-230
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,600
    Re: Newb that needs help.
    The worst thing I'm thinking is that some of the plaster itself got power washed off. Let's hope not. Any idea how old the plaster is?
    May 2016
    Duncan, Ok
    89
    I have no idea. I don't think that's it because it has got worse or grown in the last few days.
    May 2016
    Duncan, Ok
    89
    New pool owner question.
    Question is:
    FC- 5
    Ph- 7.5
    CYA- non existent
    TA-140
    TH-230
    38,284
    Re: New pool owner question.
    Welcome to TFP!!!
    Please add your pool details to your signature as described HERE as it will help us help you.
    What you are testing with?
    Any spots are something to be concerned about. Whether you can do anything about them depends on the cause.
    Can you post any pictures of what you are seeing?
    If you have trouble, note: To post more/larger pictures, you either need to raise your storage allotment by Becoming a TFP Supporter or follow the How To Post Pictures tutorial.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    How are you adding chlorine?
    You have added zero CYA? (Stabilizer/Conditioner?)
    What are you testing with?
    Jun 2014
    15,103
    Hi Coach! We're hitting you with 3 responses at once. Stains are always a concern. I'll add a couple more thoughts. Generally staining comes from either algae, high calcium, or metals in the water. I'm thinking we can rule-out calcium since you just had the pool acid washed. Let's get some more info to help try to figure this out:
    - What does the water look like now (clear, cloudy, any color tint, etc)?
    - How did you get those test results (which test kit)? We ALL want to know that one.
    - Where do you get your fill water (city, well, etc)?
    - Have you ever heard that you may have metals in the water (iron or copper)?
    Depending on how you got those readings above, I can see a couple possibilities... with no CYA either that's algae trying to form because the pool can't protect the FC; or because there is no CYA the FC is exceptionally stronger right now causing metals to precipitate out faster on to the pool surface. At some point, you might want to try a couple tests if you can ... hold a chlorine tablet to the stain, if it goes away it's organic (algae). Or try regular crushed vitamin c tablets in a sock against the stain, if it goes away or lightens significantly it's probably metal.
    Combine these first 3 replies to your situation and you'll probably have a good idea of what to do soon.
    May 2016
    Duncan, Ok
    89
    Wow thanks for the quick responses.
    Water is very clear. (At least to me)
    HTH 6 way test kit from Wally World.
    Filled with city water.
    No idea about the metals.
    Jun 2014
    15,103
    Well coach, it's not the ideal testing kit, but it's something. As already noted, you should get some stabilizer in there right away using the sock method we always speak of here. Shoot for an initial CYA target of 30 ppm.
    To increase CYA via granular stabilizer, place the required amount as calculated by the Poolmath calculator into a white sock and suspend it near a return jet or in the skimmer. Best not to allow undissolved granules to rest directly against the pool surface. Squeeze the sock periodically to help it dissipate. Once dissolved, consider your CYA adjusted to that programmed (target) level, although the test readings may take anywhere from 24 hours to a few days to fully register. Confirm CYA in about one week before adding any more stabilizer/conditioner.
    Keep your FC at the 3-5 range. Maybe try one of those tests above when you get a chance. See if you get any results. If it's algae, increasing FC to SLAM level (link below) is your method of treatment. If it's metals, that's a whole other issue we'll have to come back to.
    38,284
    I just merged your 2 threads which are essentially the same thing. Please keep related discussions and questions together. Thanks.
    May 2016
    Duncan, Ok
    89
    Quote Originally Posted by frustratedpoolmom View Post
    Putting the 3" round tablets in the skimmer and one in the thing that floats around.
    Have not added CYA yet.
    Testing with the HTH 6 way kit.
    Jun 2014
    15,103
    Coach, we don't recommend leaving pucks in the skimmer because they are so acidic and can lead to other problems. Speaking of which your pH is already on the low end, so running too much pucks could drive your pH even lower, so you should be careful about that as well. Granular stabilizer is the way to go - safe and predictable. Definitely increase/verify that CYA as soon as you can though or your free chlorine will go right out the window from the sun's UV. For sanitation, regular liquid bleach is preferred here at TFP for non-SWG pools, so you might want to review our recommended chemicals page (link below). Have a good day.
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    466
    Quote Originally Posted by Coach_1 View Post
    Those round tablets will add CYA, so you probably already have some in there. You need to buy a good test kit - a TF-100 or a Taylor K-2006 in order to have reliable results.
    SLAM * Chlorine/CYA Chart * Pool Math * Pool School
    17.5k gal IG Fiberglass, Triton II TR60 Sand Filter, Jacuzzi Magum Force Pump 1.5 hp, 3/4 hp booster, Polaris 280, TF-100 Test Kit with Speed Stir
    May 2016
    Duncan, Ok
    89
    Thanks for all the info so far. Ordering one of the recommended test kits today. Also going to put a chlorine puck against the dark spot and see if it goes away as mentioned above. Also trying to educate myself on the switch from pucks to liquid chlorine/bleach and trying to figure out how much cya to use in my pool.
    triptyx's Avatar
    Apr 2016
    1,438
    Switching to liquid chlorine just means daily maintenance. Instead of having a puck that is slowly bleeding chlorine (and unwanted CYA) into your pool over time, you check once a day and add chlorine (I pour an adult beverage and do so in the afternoon when I'm done with work). That's really it - there's no ceremony involved other than removing the existing pucks and just not using them any more.
    Testing about the same time each day will let you figure out your rough daily burn, and then you can use pool math to find out how much you need to add to cover that daily burn.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    May 2016
    Duncan, Ok
    89
    I put the puck against a few of the spots and the spots did not change. Left it there for a couple minutes. If I rubbed the puck against them some would be removed and some did not change. Don't have any calcium to try that at the moment.
    Jun 2014
    15,103
    Since the pucks didn't work, next try regular Vitamin C tablets, crushed and placed in a sock and hold against the stain(s). See if that does anything. Let us know when you get a chance.
    May 2016
    Duncan, Ok
    89
    Quote Originally Posted by Texas Splash View Post
    Will do. I need to make a Wally World run so I'll pick some up.
    30k Gallons, IG plaster, Jacuzzi Sand Storm 350lb Sand filter, 1hp Jacuzzi Magnum Force pump. Taylor K-2006 kit. Jacuzzi J-D300 side suction vac.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,478
    I also keep a long of my results. Here is something that might help you.
    Kim
  20. Back To Top    #20
    May 2016
    Duncan, Ok
    89
    So poolmath says I need 125oz of 6% bleach to raise my FC from 1 to 3. Does this seem correct? Seems like a lot to me.
