Thread: Is my CH too low?
    May 2015
    cochran\georgia
    22
    Is my CH too low?
    I opened 4/29/16 and pool was and still is clear. FC 3, CC .5, pH 7.8, TA 120, CYA 40, CH 200, Temp 72. New vinyl liner installed end of last summer. I know I need to add a little chlorine. Should I try to get my CH up to 250 as TFP recommends 250 to 400?
    33,000 gallon, IG vinyl, Nautilus FNS PacFab DE filter (7, 12 in grids and 1 partial), 1HP Hayward Super Pump Mod#SP2607X10, 3\4HP Polaris PB4-60 Booster Pump, Well Water, TF-100 Test Kit
    Jun 2014
    15,274
    Re: Is my CH too low?
    Actually Rob, the recommended CH for a vinyl pool is 0-350 (non-SWG), so you're good. Leave it.
    Aug 2014
    Northern IL
    4,615
    Agreed about the CH. Your FC is at the borderline as you mentioned. Up it a bit as per: Pool School - Chlorine / CYA Chart A little MA wouldn't hurt to start working on that TA.
    May 2015
    cochran\georgia
    22
    Thanks for the advice!
