Thread: Small space shell virginia
    Where can I buy a small 6'x6' spa shell near Virginia and how much do they cost? I see San Juan pools have a Cove spa that is what I want but I just want the shell.
    Thanks
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Small space shell virginia
    interesting, I have not heard of anyone buying just the shell
    This might require some call to the manufacturer..
    I am in the middle of a pool install and the installer cracked the patio under my hot tub so time to go inground with that too. My pool equipment can support a spa so just need the shell and I will plumb it from the pool heater.
    Blacklisted's Avatar
    Sep 2013
    El Cajon CA
    126
    Look on craigslist in your area, In my area you can normally find free or real cheap hot tubs that need plumbing or wood work but still have good shells. I just re read your post, why not use the one you have and gut it?
    Intex 15'x42" Metal Frame pool 4200 GAL with Intex SWG. TF-100 test kit. Our Pool Install Thread
    In Work! Master Spas Legend Series LSI 557 3-4 person Hot Tub, 230 GAL using bromine to sanitize it. Hot Tub Install Thread
