Thread: PH question (should be easy)
    May 2012
    Allentown, PA
    219
    Just got done opening and passed the SLam
    FC 10.5
    PH 7.0
    CYA 45
    salt 2200
    I'm slowly letting the FC settle into about 7, but just tested the PH (it has been a while since before the slam). It is low, and I know higher FC levels can make the test invalid. I'm wondering if I should raise the PH or if I should wait a day or two and test PH again and then add washing soda? Thanks
    21,500 Gallon Vinyl liner pool Eastern Pennsylvania
    Hayward 2 HP pump 2" Pvc pipes Full Sun Pool
    Hayward sand filter, Compupool CPSC 48 SWG
    12mil solar cover and reel
    Aug 2010
    Dallas, TX
    4,052
    Re: PH question (should be easy)
    You are safe at 7.0. Test when FC comes down.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    I would wait until FC is below 10 and also check the TA. If TA is high enough, just aerating the water should raise the pH without any chemicals. If TA is low, then add soda.
    May 2012
    Allentown, PA
    219
    OKay thanks. Richard what would consider high enough for the TA in order to aerate? I will check the level of mine tomorrow. Before I shocked TA was about 70 if I recall correctly. Regardless, I will check it again tomorrow.
    Richard320's Avatar
    Jan 2010
    19,071
    Quote Originally Posted by doublewide6 View Post
    70 is high enough. Anything above is even better.
