Results 1 to 10 of 10
Thread: Pool Liner Issue
    May 2016
    Wind Gap
    8
    Pool Liner Issue
    This is the 3rd season that I've had my pool and gradually the liner below the skimmer basket has puckered and became extremely faded, thin and now has small rips in it. The rest of the liner is in great shape. Is this a chemical issue, liner issue, installation issue? I want to make sure I understand, before i go buying another liner.
    thanks,
    Tommy
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Pool Liner Issue
    Do you use trichlor tablets in your skimmer basket?
    Isolated Spa - 345 Gallons
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    how are you chlorinating? looks like tablets in your skimmer basket and when its not running the super high chlorinated water is breaking down your liner. You also have an algae outbreak and need to SLAM. in order to do that you need to read up on pool school and get yourself a test kit
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    May 2016
    Wind Gap
    8
    Yes I'm using trihlor tablets in the skimmer basket.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Wow that is seriously damaged. I don't know if that is repairable, but you should not be putting them in the basket.
    That burned your liner up.
    And better yet use bleach instead of pucks.
    Dolphin E10 Cleaning Robot.
    Feb 2014
    Central Minnesota
    5,080
    There's some good pictures here of what happens when you have trichlor tablets sitting in a skimmer basket. Both liner damage and plumbing line damage. Vinyl Pools, Pool Liners, Pool Service, Pool Renovations in Bucks County and Montgomery County | APCO Pools Specialties, Inc.
    As Dan mentioned, trichlor tablets are acidic and create a super chlorinated environment, especially when the pump is off and the tablet is still dissolving. This is why many pool services that stuff your skimmers full of trichlor tablets instruct homeowners to run their pumps 24/7 as it reduces that problem, but does not eliminate it. It's also expensive (electricity) and not necessary to run your pump 24/7 for filtration. If pucks must be used, they should only be placed in a floater in the pool and monitored so they don't sit in one area.
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    i would suggest you get a new liner, and then read up on the TFP method (pool school link at top of page). We can help save you a lot of time and money and have an always clear pool. our method resolves around having an accurate test kit (TF100 is best value), and no, pool store testing is NOT accurate. we keep our chlorine levels based on the stabilizer (CYA) level, and we never need to shock the pool. we chlorine using liquid bleach (or saltwater systems).
    if you are not interested in following the TFP method, thats fine too...but do yourself and get a floater to put those tablets in and stop ruining your liner
    Dan
    May 2016
    Wind Gap
    8
    Thanks everyone for the quick response!! I just ordered a new liner and will scrap the tablets and review the methods recommended.
    May 2016
    Wind Gap
    8
    _DSC1065.jpgPool liner replacement complete!
    triptyx's Avatar
    Apr 2016
    1,438
    Now that's a lovely looking pool. Let's keep it that way with the TFP method.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
