Thread: Trichlor feeder options for variable speed pumps?
    Apr 2014
    Pacific NW
    5
    Hello,
    I know the issues with Tricolor sanitizers but have been using them without issue for the last 9 years but want to switch over to a feeder vs floater with the new pool heater. Does anyone have any experiences using these with variable speed pumps as I've read some issues exist. Normally during filtration it runs at a lower speed but during the gas heater use and solar panel use it speeds up and I've read that can play havoc with them.
    Any thoughts and experience would be appreciated.
    Aug 2010
    Dallas, TX
    4,052
    Re: Trichlor feeder options for variable speed pumps?
    Why not upgrade to a salt system so you can solve two problems at once?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    I run my VS pump at 1100 rpm to skim, filter and make chlorine with the SWG. It uses 150 watts. At 10.25c/kWh I can run it 24x7 for 12 bucks a month. I run solar at 1950 rpm and it uses 550 watts. Been running like this for 4 years, works great!
    30,402
    Pretty straightforward math. If you increase your pump speed, you will increase your FC output by about the same percentage. Complicated if you are adding chlorine 3-4 times daily, for sure.
    Dec 2015
    Newington, Connecticut
    113
    I had a new water in line which cane with the frog system. My vp pump ran 3800 rpm for 12 hrs a day. Of course this was a single speed so once I got it turned in it was great . Rainy days I would bump it up or down. Quit convenient. I was just unaware of the rising cya.
    16'x34' Kidney 17000 Gallon IG Vinyl liner. Pentair IntelliXF vs pump, Sta-Rite System 3 DE filter. Liquidator, TF-100 Test kit w/ speed stir. Aqua Comfort heat pump, Dolphin Apollo robot, clear solar cover, stamped concrete deck.
