Results 1 to 8 of 8
Thread: Uncovering pool first time in 4-5 years
    Apr 2016
    Baton Rouge, Louisiana
    7
    Uncovering a pool for first time in a long while. Of course it's green and nasty but the sides of liner are coming off with water behind in several spots. Would like to slam it but do I need to fix liner first?
    Baton Rouge, Louisiana. Kidney shaped inground vinyl pool 14x36, approximately 20,700 gallons. Hayward 24" sand filter with Century Centurion 1hp pump, also has booster pump but can not read label.
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Re: Uncovering pool first time in 4-5 years
    wow, this one might be some fun! are you able to get the liner back into place?? you can lower the water a few inches and use near boiling water to pour on the liner to allow it to stretch a little bit. if you cant get the liner back into place, there is no point in SLAMing it to clean it, you are going to have to replace the liner. looks to me like you should be able to get it back into place with some muscle. after that....its going to be a LOT of bleach and a lot of scooping out gunk from the pool. first thing, see if you can get that liner back into place. and welcome to TFP!
    if you can get the liner in place, that pool will be sparkling clear in a few weeks, we have seen much worse here!
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Apr 2016
    7
    Thanks for the fast reply, looking closer now it appears to have about a foot long tear in liner right around a jet site, looks like I'll be replacing the liner. Glad to have found this forum, and hopefully after liner is replaced will never have a green pool like this again!
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Quote Originally Posted by brbrian View Post
    Be sure to come back after the new liner to start fresh using the methods taught here... you won't regret it!
    38,342
    Welcome to TFP!!!
    Bummer about the tear ... I was hoping to get to watch this one get cleared up
    11,969
    Welcome to TFP!!!
    Me too! LOL
    May 2016
    Campobello, SC
    7
    That stinks that it's torn....that would have been a fun one to watch back to life. I feel for your upcoming liner installer too!
    Pentair Intelliflow 3HP Pool Pump, Pentair IC40 Salt Chlorinator, Jandy Sand Filter
    Pool Size- approx 26,000 gallons; 18 by 34 rectangular w/ a liner
    Aug 2014
    Northern IL
    4,615
    Good luck! We can help you get your chemistry balanced after the new liner. Better to trust us than your PB!
