Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: New to this, just emptied and filled my pool with city water
    lmigoni's Avatar
    May 2016
    Oro Valley, Arizona
    17
    Question New to this, just emptied and filled my pool with city water
    After checking my pool water and finding extremely high CYA levels I decided to just start from zero with new city water.
    5/6/2016 5/10/2016
    FC (Cl-Br) 0 3 - 6
    TC 0 3 - 6
    CC 0 0
    pH 8 7.4~7.5
    Acid Demand 2 NA
    Base Demand NA NA
    Total Alkalinity (ppm) 140 120
    Calcium Hardness (ppm) 90 110
    Cyanuric Acid 0 0
    This is what I have as of today. I added some Muriatic acid on May 6th to lower the pH and Alkalinity levels.
    I also added some shock to the pool since I started to see signs of algae on the bottom of the pool.
    What should I do next?
    Can I start adding Cyanuric Acid (staibilizer) or should I get the Calcium Hardness under control. I also feel inclined to add bleach so that I may begin to increase the chlorine levels.
    Migoni
    20,000 Gallon in-ground PebbleTec pool, 1.5 HP Pump, Pentair Quad DE-80 filter, In-Floor Cleaning CareTaker, city water, K-2005 test kit.
    My Real Helmet assemble, paint and collect
    Aug 2010
    Dallas, TX
    4,052
    Re: New to this, just emptied and filled my pool with city water
    What is in the "Shock" stuff you used? It may have CYA in it, and you'll need to use the Pool Math calculator to see what effect it will have on your pool.
    Is the FC still zero and you still have algae? If so, you need to SLAM the pool water. I'd address the CH issue first though. And, get the pH in line.
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    I would get your CH and CYA addressed asap. just go to pool math and it will tell you how much to add. i would just go for CYA of 30 for now, as the summer goes on you can always increase it as needed. i would just buy some granular stabilizer since you are at 0. you can always use the bagged shocked later in the season to help increase your CYA if desired.
    but yes, with a plaster pool, get the CH up.
    If you have algae, you need to SLAM asap. get it done now and dont let it get going too far. get the stabilizer to 30 by adding CYA and start your SLAM. lower your pH to 7.2 before you start. once you start, you cant test pH until you are done
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    lmigoni's Avatar
    May 2016
    Oro Valley, Arizona
    17
    Awesome, Thank you for the quick advice.
    I will start adding the CYA using the sock method and get my CH level up. I am not too concerned with the Algae yet but I will do a SLAM as soon as the CYA level is up and I have increased the CH.
    Migoni
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Also please add a state to your location as some of our advice will vary depending on the region you live in, for example AZ is prone to high CH fill water and high evaporation rate and low rainfall which concentrates CH over time, you are very lucky to have a low CH fill water source. You are also in a prime sunbelt location so we would tend to suggest running your CYA towards the upper part of the suggested range, say 50 ppm with manual chlorination.
    triptyx's Avatar
    Apr 2016
    1,438
    Oro Valley is just a hair north of Tucson.
    High CH, high evap rate, low rain, fill Ph around 7.8, 175 CH, .5 FC.
    If your pool isn't covered, step one is to get CYA up to 50 30 (jblizzle has a point about leaving it a bit low to SLAM). I'm slowly working mine up after a nearly complete water replacement last weekend to avoid a 4 ppm FC burn off daily. While you're doing that, since you already have an algae problem, work hard to get that FC up to at least retard growth.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    38,470
    I am just south of oro valley.
    I would leave the CH and keep the pH on the high side. You will add around 150ppm of CH to your pool yearly just due to evaporation. I am over 500ppm now and started with 130ppm.
    If you see algae, you need to slam. Add 30ppm of CYA, slam until you pass the 3 criteria to stop, then raise the CYA to 50ppm and maintain adequate FC from there on out.
    lmigoni's Avatar
    May 2016
    Oro Valley, Arizona
    17
    Thanks for the advice.
    I now have my pH down to 7.2 and I added 5 lbs.s of Calcium Chloride. I started with 90 ppm of CH and now I am up to 150 CH. From what I understand here in Arizona the CH will only go up as the water evaporates over time so I am not sure if I want to add more Calcium as of right now.
    I also added about 2 lbs. of stabilizer and I am adding more now. I will check the CYA level tonight with the hope that I can start my SLAM.
    One more question, after I do my SLAM, how long does it typically take for the FC levels to come down and for the pool to be in a swimmable condition?
    Migoni
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    dont worry about checking your CYA, it wont show up in the tests for up to a week. once its fully dissolved (you can speed it up by squeezing the bag), its in there and you base your SLAM FC values on the new CYA level (old plus whatever you added).
    second question, you can swim with your FC up to SLAM level. it will take a while to drop your FC since the water will be so clean and void of any algae to break it down. Count on 2 ppm per day at this time of year i bet. but i swam once it dropped below the SLAM level and it was fine.
    Dan
    lmigoni's Avatar
    May 2016
    Oro Valley, Arizona
    17
    Thanks Dan!
    Here is another question about my pool pump set-up.
    I can't figure out what those large pipes going into a single smaller pipe are for.
    Also I can't figure out which return lines correspond to what in the pool.
    Any ideas?
    Migoni
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    are you referring to the ones at the bottom right of the picture, basically in the foreground in front of the pump? its not connected to the return from the pool to the pump, right? could it be electrical to lights, etc?
    as far as the returns go, only real way to figure it out is to close one completely. if your pool is still skimming, the one you close was the main drain. and vice versa. then label them on the pipes with magic marker
    Dan
    38,470
    Open the 2 Jandy valves after the filter (one at a time) and see what they do
    No idea what the big-to-small pipe loops are for.
    FYI, your "Pool Pump" label is point a motor, the pump is what the motor is attached to.
    Quote Originally Posted by DaninFLA View Post
    You are mixing things up. There is only 1 suction line. The valves are on the returns.
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    figured there was another valve on the suction side...missed he said returns. OP - do you only have skimmers, or is there a drain on the bottom too?
    Dan
    lmigoni's Avatar
    May 2016
    Oro Valley, Arizona
    17
    There is one skimmer and a drain at the bottom. There are actually three "drains" at the bottom of the pool not sure if they are all connected but one is a leaf trapper and the others look just like normal drains.
    For the return lines I have played with every Open/Close combination of valves but I can't get one side of the return lines to flow. Not sure if there is some blockage somewhere or if I am just missing something in terms of opening and closing the valves correctly.
    Migoni
    lmigoni's Avatar
    May 2016
    Oro Valley, Arizona
    17
    Pool water is looking clean and clear, I am currently holding the Chlorine level at 10 while I continue to add some CYA and wait for the total CYA level to be raised to 30.
    Do I need to add clarifier to the water in order to trap all of the smaller particles floating around or is that just a matter of personal preference?
    Migoni
    Jun 2014
    15,221
    As nice as that pool and water look, the only thing I would put in it is ME.
    lmigoni's Avatar
    May 2016
    Oro Valley, Arizona
    17
    Just come on over and enjoy the Arizona sunshine. I think there will be plenty of margaritas flowing this week end.
    Migoni
    38,470
    No clarifier is needed, just filter longer if you care.
    You are going to want your CYA up to at least 50ppm in our sun.
    Also, you should add the FAS-DPD Chlorine Test to your kit so you have the equivalent of the recommended K-2006
    lmigoni's Avatar
    May 2016
    Oro Valley, Arizona
    17
    Thanks for the tip, I just ordered the FAS-DPD Chlorine Test. I will continue to add CYA to increase the level, as of right now I have added about 4 lbs of stabilizer which according to the packaging they recommend to add 1 Lb. for every 3000 to 4000 gallons. I did not test CYA this morning because I understand it can take days for it to show up in the readings.
    Because I continue to add CYA, how often should I be checking it and how long should I wait for it to show a stable reading?
    Migoni
  20. Back To Top    #20
    38,470
    How are you adding it?
    We recommend putting it in a sock and hanging it in front of a return jet or setting it in the skimmer.
    Once it is out of the sock, it should show up on the test.
    You should start using PoolMath to do the calculations for you.
