Thread: Re-orienting Intex 2650 filter 6 way valve to allow proper hard plumbing to pool
    Mar 2016
    Wantagh, NY
    33
    I started to put up my 14X42 Ultra Frame pool yesterday, and placed my new 2650 Intex sand filter next to it.
    Once thing I noticed is for me to do the straightest plumbing is that I need to rotate the 6-way valve approx. 90 degrees so the output pipe will run straight to the return port in the pool
    I can't turn the entire pump 90 degrees because my intake/ input from the skimmer would not be lined up.
    So that means now instead of using the short intex hose that connects the pump to the 6-way valve, I need to hard pipe it.
    Has anyone done this before? Can I use the same "box adaptor" PVC connection that is used to connect to the pool?
    Or did anyone come up with another solution rather than turn the 6 way valve?
    Jun 2015
    Stockholm, Sweden
    250
    Re: Re-orienting Intex 2650 filter 6 way valve to allow proper hard plumbing to pool
    Yes, same connector. Go for it, no problem.
    Intex Ultra Frame 24'x12'x52" (732cm x 366cm) rectangular pool
    Intex SF80220RC (1600 GPH) pump/sandfilter
    Intex SF10220 (1050 GPH) pump/sandfilter driving the
    Intex Automatic Pool Cleaner
    Intex 8220 ECO SWG, Brilix XHP100 9kW heatpump
