Thread: Best Solar Heater for Canadian climate?
    Jun 2015
    Ottawa/Ontario
    340
    Hi folks
    Looking for any comments, suggestions, tips, insight and anything else that comes to mind for a solar hot water system for our pool? I need to find one that is available in Ontario Canada...i am very green on what the best and worst brands etc...any help would be appreciated!
    Right now we have a propane heater (Hayward), but I am too keen to use it to raise my pool temp from the 51 it is right now using propane alone...
    Cheers all
    Tom
    68,000litre, IG vinyl, LorentzPS 600 Solar Pump & 1/2 HP Tristar, Sandfilter, Aquarite T-15 SWG
    20000 gallon, IG, SWG, Sand Filter, Hayward 1/2HP + Lorentz direct solsr PV pump
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Best Solar Heater for Canadian climate?
    The trick with solar heating is square footage
    These guys have good reviews... and they have a website up your way
    Solar Pool Heating in Vancouver, BC
    Isaac-1's Avatar
    SW Louisiana
    6,711
    The question is also are you looking to increase your peak summer temperature or are you looking at extending your swim season, if extending swim season, then the question is by how much. I find that my traditional unglazed Techno-Solis panels provide positive heat input as long as the daytime high is within about 20 degrees F of the desired pool temperature.
    p.s. Glazed panels or evacuated tube system only out perform glazed panels when the temperature difference between pool temperature and daytime temperature is more than 20 degrees F. Also glazed or evacuated tube panels are far LESS efficient per sq ft, so it takes more of them to achieve the same number of BTU's when the pool temperature is within 20 degrees of the daytime temperature. In other words the traditional black plastic mat pool solar panels are best when you have daytime temperatures in the 60's or above.
    Jun 2015
    Ottawa/Ontario
    340
    Quote Originally Posted by Isaac-1 View Post
    Extending season...
    Techno-Solis seems to pop up alot...
