Results 1 to 13 of 13
Thread: 3 week vacation later in summer - advise on how to handle pool while gone?
    Jun 2015
    Mesa, AZ
    22
    So, we're taking a 3 week vacation later this summer, getting out of Phoenix and seeing some family, etc. I'm trying to figure out the best way to handle the pool. I don't have anyone to check the pool on a daily basis, but probably could have someone come by once a week to throw in some chemicals. Given that it's monsoon season at that time in AZ and we have some neighboring trees that like to drop leaves and stuff in our pool, I'm concerned with leaving the pump going while I'm gone and having the skimmer and leaf catcher in the cleaner line be totally clogged so it can't run properly and burn out the pump or something. But I don't like the idea of not having it run for three weeks, just not sure I have a choice. Could I get away with using a few pucks (CYA is fairly low now) in a floater and having someone throw in a good bit of chlorine once a week and not having it be a total disaster? I'd appreciate any input/suggestions. Thanks.
    18k gallon in ground pool. Whisper flow pump, Pentair FNS 48 DE filter. Pool interior resurfaced with mini-pebble in May 2015. Kreepy Krawly Sand Shark Cleaner. Taylor 2006 test kit. Shade structure over shallow end of pool.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: 3 week vacation later in summer - advise on how to handle pool while gone?
    A cover of some kind would be very helpful in keeping the leaves out of the pool and skimmers as well as preserve some of your FC. Other than that, you have a fairly good plan with some trichlor pucks, someone to check the skimmers a couple times a week, maybe a basic color block test for FC if they can handle it.
    Isolated Spa - 345 Gallons
    Jun 2015
    Mesa, AZ
    22
    A cover is probably a good idea and would allow us to keep the pump running. Any ideas on where to buy a decent quality cover inexpensively. We probably wouldn't use the cover other than when we're on vacation so it won't get a lot of use.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Do you have a bottom drain? Our skimmers get clogged all the time by trees. We set the suction valve to about 80% skimmer and 20% bottom drain so the pump can always get water.
    If your PH rises lower it to 7.2. And raise your FC to shock level for your CYA, Chlorine CYA Chart
    Oct 2015
    Austin, TX
    83
    I am in the same situation - keeping my CYA low now so I can use pucks later. I have an in-line chlor, my plan is to clean and balance the pool the day before, then raise the pool to SLAM level with bleach, drop as many tabs as will fit in my in-line chlor (I think 5), set the in-line chlor on setting 2 (of 5), and put on my solar cover.
    Pool: 16,000 gallons, 16x31, 500SqFt gunite pool, White Pebbletec interior, built by Cody Pools. Pentair Intelliflo VS-3050 pump, Pentair Clean & Clear 420 Cartridge Filter, In-line chlor with Ultra UV, PV3 Infloor cleaning, Pentair Easytouch-P4 control. TF-100
    Spa: 525 Gallons, Coast fiberglass spa of unknown vintage and suspect previous care with a 2-speed main pump and a blower motor, both 4HP. 3-step bromine sanitized.
    Feb 2014
    Central Minnesota
    5,080
    As far as covers go... you could go as low budget as a tarp that's large enough to cover the pool. The trick is anchoring it reliably. Manual winter covers with water bags are the least expensive option that are designed as pool covers. Examples here: Fine Mesh Covers for Swimming Pools - from PoolCenter.com
    Even a very cheap 8 mm solar cover would help.
    Jun 2015
    Mesa, AZ
    22
    A cheap cover is on the way. So I guess for pH, there's not much to do other than drop it down fairly low and then deal with the high pH when we get home? Ours trends upward and would probably be quite high after three weeks of no muratic acid.
    JoyfulNoise's Avatar
    May 2015
    13,231
    Quote Originally Posted by bgray9 View Post
    Rather than dropping your pH aggressively (it just comes up faster the lower you go), you'd be better off dropping your TA aggressively as that is the source of pH rise. Adding borates will also help keep high pH under control (and act as a mild algae inhibitor). pH rise is not linear, but self-limiting. A pool will roughly rise up to about a pH of 8.5 or so and stop there for a long time. So if you aggressively manage your TA (and assuming your CH isn't off the charts), you can get away without having to add acid for your vacation. Even a weekly dose to drop it down to 7.6 will be fine.
    Matt
    Feb 2014
    Central Minnesota
    5,080
    Very much this. Are you having issues with pH rise currently? What is your TA?
    May 2015
    Kaplan louisiana
    69
    I work away from home on a 7/7 rotation so I go thru this weekly, I'I usually load my in line chlorinator with pucks the day before I leave and bring the pool up to shock level with bleach while lowering my PH to 7.2 By the time I get home the next week my Ph is usually in the 7.6 range and chlorine is never low. My wife and kids use the pool routinely while I'm gone but my wife refuses to learn how to handle the chemical balance so I'm left with no choice but to use pucks every other week until I decide to spend the money an a SWG.
    13500 gallon above ground with pentair sand dollar sand filter, 1.5hp pentair pump with TF-100 test kit. Kaplan, Louisiana
    Jun 2015
    Mesa, AZ
    22
    Quote Originally Posted by JVTrain View Post
    My pH rises gradually, with me adding a bit of muratic acid maybe once a week. I'm not that worried about it generally, but I'd expect it to be pretty high after three weeks, absent someone possibly coming by to add a bit of muratic acid once a week. TA is around 50 to 60.
    Jun 2015
    Mesa, AZ
    22
    Another question. If I have someone come by once a week to put in a bit of chlorine and muratic acid, is there any problem with adding both to the pool at the same time (not the same moment of course, but within a few minutes of each other)? Thanks.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,077
    It's better to let one mix a little before adding the other. If you have 2+ returns, you could add them at different returns with less wait time.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
