Results 1 to 9 of 9
Thread: Constantly adjusting SWG %
    Flbeachluvr's Avatar
    Mar 2016
    Port Orange, FL
    373
    Still figuring out this whole pool ownership thing... I test for chlorine and pH daily. As the pool is new I'm still having to add MA daily. With my CYA of 70 I'm trying to keep my FC right at 5. Right now it seems to bounce around every few days which means I have to adjust the % on the SWG. Last week the FC got up to 7.5 so I turned down the SWG a bit and last night I was down to 4.5. Is it normal to have to make frequent adjustments to the % on the SWG? Currently my pump is running 8 hours per day and the SWG runs at the same time.
    Pool completed 3/21/2016
    8800 gallons, plaster 14' x 24', 3/4 hp Hayward pump, Hayward cartridge filter, Blue Essence T-5 SWG, Kreepy Krauly Kruiser, Taylor K-2006 test kit with Speedstir, Taylor K-1766 salt test and 250 sq. ft. of Heliocol solar panels with Pentair Solartouch control system
    Aug 2010
    Dallas, TX
    4,052
    Re: Constantly adjusting SWG %
    FC is impacted by a variety of factors - water temperature, organics in the pool (bugs, leaves, etc.), amount of sun on the pool, bather load, etc. So, FC will fluctuate some. But, you should be able to get it stable enough so that you only need to do weekly checks.
    Mar 2016
    Port Orange, FL
    373
    So adjusting a few times a week is normal? Seems like the FC creeps up and then I turn down the SWG and it's too low so I have to bump it up again and then it's too high again...
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    This time of year is tricky with rising temps, increasing sun, more rain cooling the pool, etc. The MOST important number is minimum, Chlorine CYA Chart. You want to make sure FC never drops below minimum or the pool will be u sanitary and algae can grow. It is fine to be above target a few PPM to make sure this doesn't happen. It is safe to swim with FC up to shock level for your CYA.
    Mar 2016
    Port Orange, FL
    373
    Quote Originally Posted by pooldv View Post
    Ok thanks. I won't worry so much when it creeps up and just leave it alone. My OCD like to have me mess with things
    DFW, TX
    24,514
    LOL! You need a beverage and a floatie to mess with!
    Mar 2016
    Port Orange, FL
    373
    Well hopefully the water will be warm enough for me to go in this weekend with said beverage and floatie. Two weeks ago water temp was at 87 which was great but this past weekend it was back down to 77. Way too cold for me. Looking forward to our solar installation next month!
    DFW, TX
    24,514
    Yeah, our pool is jumping between 83 and 74. Solar is great! We are 85 water people. Although, I am in 83 water right now and no complaints! But, it is only 88 outside so it is good. Our pool went from 74 on sunday to 83 right now.
    Dec 2014
    Sydney, Australia
    43
    You will get a little finer adjustment by adjusting run time, either leave on the lower setting and increase run time by 1 hour or leave it on the higher setting and reduce run time by 1 hour
    test various run times until you get less of a swing.
    Then as the summer comes you'll need to do it all over again as the increased Sun/UV depletes more FC during the day.
    8M x 4M Inground Concrete, 40k Litres, Waterline Tiles/Quartzon, Viron P320 VS Pump, Sand Filter(Glass Media) Astral VX-9 SWCG, Heatpump w/ Solar Cover. Zodiac V3 4WD Robot. Bullfrog A8D Spa(1800Litres).
