Thread: How to remove DE from water
    May 2016
    Toronto
    1
    Hi everyone..... second year opening pool and I screwed it up already. I added my 9 lbs of de.... Then noticed that it was going straight into the pool. I took the filter apart and there were no issues with it. Turns out I didn't have it seated correctly in the base which is why it was circulating back into the pool. What is the best way to get rid of the excess DE? I placed the filter back in... Added DE to it so it was coated and would hopefully pick up the DE in the pool via filtration. Should I leave the filter running? Or leave It off and let it seems to the bottom and vacuum it up? Will I be able to get it all out? I have an inground 20x40 foot pool with a star rite 3 filter
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: How to remove DE from water
    Welcome to TFP!
    I would leave the pump off for a while to see if you can allow it to settle on the bottom. Then try to vacuum it up manually if you can see it. Manually giving the whole pool a vacuum would get nearly all of it if you allowed it some settle time prior.
    Isolated Spa - 345 Gallons
    JoyfulNoise's Avatar
    May 2015
    13,193
    Matt
