Results 1 to 7 of 7
Thread: Open for business
    tlcottone's Avatar
    Jul 2013
    Summerville, SC
    69
    Open for business
    Opened the pool for the season at last. The effects of raising the chlorine levels high before covering last year is as follows.
    CYA - 20
    FC - 4
    pH - 6.8
    Water is crystal clear. So right now raising the pH. Should be a trouble free season.
    BTW for anyone interested, Walmart is carrying liquid chlorine by Pool Time. $2.50 a gallon. Stock up everyone
    6423 AG Intex 18 x 48 Intex 2100 GPH Sand Filter Pool Pump TF100 test kit
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Open for business
    Nice to see some FC at opening! Usually means you'll have an easy start up after opening. I've seen a few folks with a bit lower pH at opening as well. How is your TA level? Make sure you know that before attempting to adjust pH.
    Isolated Spa - 345 Gallons
    tlcottone's Avatar
    Jul 2013
    Summerville, SC
    69
    Initial TA was 70
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Would you say you have a Troublefree Pool?
    May 2015
    Paxinos PA
    57
    Quote Originally Posted by tlcottone View Post
    What is the percent chlorine in this product? Did you find it in the pool section?
    22,000 gal 16x34, IG, vinyl (7/14)
    DE Hayward Perflex extended cycle
    Hayward Super Pump
    Aquacal heat pump
    TF-100 test kit
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    10% in the Pool area. Just watch the datecode.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    May 2015
    Paxinos PA
    57
    Quote Originally Posted by pabeader View Post
    Thanks. Looks like they're out of stock
    Hayward Super Pump
    Aquacal heat pump
    TF-100 test kit
