Thread: Do you guys think this pool skimmer would work connected to my pressure return line?
    Apr 2016
    Youngsville, LA
    274
    Amazon.com : PoolSkim Pool Skimmer and Pool Cleaner : Swimming Pool Maintenance Kits : Patio, Lawn Garden
    I took out my old pressure side Polaris pool cleaner a few weeks ago when I bought a new Dolphin vacuum and was thinking about possibly attaching this to that dedicated pressure return line and run it off the booster pump timer. It would be perfect because I could set it on the timer and have it skimming at the exact time I'd want it to. My pool skimmer doesn't do the best job of removing surface debris and I thought this would work well. It wiould still leave my other three pool return jets open too.
    I've found a 2" threaded male to 1.5" threaded female PVC reducer, so that it would fit in the pressure return line. What you guys think?
    15k Gallon In Ground Saltwater Gunite Pool and Spa w/ Overflow
    Dolphin Nautilus Plus Pool Cleaner
    Main Filter Pump - 1.5HP Pentair Whisperflo connected to Triton II Sand Filter
    Spa Pump - 2HP Pentair Whisperflo w/ 2HP Polaris Spa Air Blower
    Resilience PSC3 SWCG
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Do you guys think this pool skimmer would work connected to my pressure return li
    some have reported good results with that one
    Aug 2010
    Dallas, TX
    4,052
    I keep mine connected to a return at all times. No reason to turn it on/off that I can think of.
    If you don't get enough pressure, you can change the other three returns to these, which is what I did. I run a VS pump and have it set very low, so I had to change the other returns to get the PoolSkim to work.
    Amazon.com : Pool and Spa Eyeball Jet 1.5 Garden
    Apr 2016
    Youngsville, LA
    274
    Quote Originally Posted by cowboycasey View Post
    Do you think it would work properly connected to my booster pump/pressure return line?
