Results 1 to 8 of 8
Thread: Intex sand pump dieing
    So I have one intex sand filter motor frozen and another that isn't sounding too swift. Anyone ever replace the motor with something better and continue using the sand filter itself? If so how is it working?
    What pump would you suggest? We have a 21 round by 52 deep intex ultra frame.
    Intex ultra frame 22 x52
    intex sand filter and pump
    intex saltwater generator
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Intex sand pump dieing
    The 14" filter (if you have that one) is certainly undersized for your pool. You'd be much better off with a 18" or larger 21-22" filter. Larger filter = less backwashing. For pump size, I would look at a 3/4 HP or 1 HP pump. Hayward makes a few combination packages in this range, otherwise you could purchase what you like separately. For example: Amazon.com : Hayward S180T92S Pro Series 18-Inch 1-Horsepower Top-Mount Sand Filter Power Matrix Pool Pump : Swimming Pool Sand Filters : Patio, Lawn Garden
    Isolated Spa - 345 Gallons
    Thanks for the reply. I don't seem to have a problem as far as the filter size. Once it's clean and running I don't backwash very often at all. I was thinking of a Hayward 1 hp but wanted some advice from people here that have likely had alot more experience than me thanks again
    Jun 2015
    Tallahassee, FL
    30
    My pump died and I replaced with another newer intex. Pump and filter $157 from amazon. Handles my 18 x 48 nicely.
    Intek 18' X 48" AG, filled to 36-42"(slope?), Intek sand filter/pump, Hayward skimmer
    Can you give me the model you replaced it with? I can get a replacement from intex for $95 but was thinking of going with something that would be of better quality
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,549
    After going through 2 Intex pumps in about 4 years, here's what I did. $229 at Wal Mart, couldn't be happier.
    New pump arrived today
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Jun 2015
    Tallahassee, FL
    30
    Intex Krystal Clear Sand Filter Pump for Above Ground Pools, 3000 GPH Pump Flow Rate, 110-120V with GFCI
    Cheers
    Actually only the bearings on the motor died, and youtube vids show a pack of $10 bearings and time is all it takes to bring back to life.
    Thanks for the info. We'll one of mine was stored in the attic but little did I know I had an ant infestation inside the pump. We'll pulled it out to replace the current one and its rusted in place.
    The current one sound bad like it almost has a ping sound to it while running not really a grinding sound like bearing would make.
