Thread: Pool Heater
    Pool Heater
    Good day all.
    First I would like to thank everyone in this community for everything. I love this site.
    Quick question.
    I have a raypak 255 000 btu pool heater and want to heat my pool but the question is my pool is 60 right now and I want to bring it to 80. Will this cause any over heating issues if I run the pool heater 24/7 or should I slowly increase the heat over the next week.
    Please and thank you
    Sorry Guys forgot my signature.
    23000 gallon inground pool, Vinyl liner with hayward sand filter, 1.5hp hayward pump with TF-100 test kit. Raypak P-R266A pool Heater
    Re: Pool Heater
    Quote Originally Posted by joe111 View Post
    Good day all.
    Quick question.
    I'll defer to the pro's but I don't think I would sleep too easy with a gas heater running all night. What about one of those cheapo solar blankets, (the bubble wrap type) and run the heater during the day? Assuming there are enough folks around to spot / smell any issues during the daylight hours, if not then I don't guess it makes much difference.
    Re: Pool Heater
    Quote Originally Posted by iceflow View Post
    We do this frequently (well, as often as we need to when we have people coming over the next day and the water temp has dropped appreciably) without incident.
    Geebot
    Chicago, IL
    30K gal, InGround Plaster Finish, 3.5'-9.5', Maytronics S300 Cleaner
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Re: Pool Heater
    No problem with doing this. You might be surprised that it would heat quicker than you think. Invest in a solar blanket to keep the heat in.
    What are the outside temps where you live?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Pool Heater
    Glad to see I'm not the only one getting duplicate posts.
    I have the same heater, my pump and heater run 24/7. There is no problem doing this as I've done it annually in the spring.
    Re: Pool Heater
    Thanks Iceflow great idea.
    Thanks everyone for your input. I live in ontario and the current temp is 11 Celsius or 56 F. I do have a solar blanket as well. I am mostly concerned about over working the pool heater having it run for over 15 hours straight to increase the pool 20 degrees.
