Thread: Recalibrating IntelliChlor IC40
    Hello everyone, i was told that i can come to this site to find out how to recalibrate my Intellichlor Electronic Chlorine Generator. Someone please help me before i do something that creates a problem for my pool. It will be highly appreciated.
    Thank You,
    18ft Round 48" Deep Above Ground Vinyl 7,600 gallons
    1.5HP Pump - 200lb Sand Filter - Polaris 65 Pool Cleaner
    BBB Method
    Pisces's Avatar
    Jun 2008
    League City, Texas
    Re: Recalibrating IntelliChlor IC40
    Hi Christopher...I'm not a mod, but welcome to TFP...I know others will be along to help and welcome you!
    Go to the "Salt Water Generators (SWG)" category. There are several threads, but this will get you started: continuous-red-cell-light-t11473.html
    There is a link Spishex gave out that gives directions on recalibrating. I just recalibrated mine. Be sure you know approximately what your salt level is, as close as possible. Don't rely on "pool store" numbers, or what the Intellichlor reads. Get the Aquachek Salt strips (while you're at it, get 2 bottles and compare the numbers with a test from each bottle) and check your salt level. Good salt levels for IC-40's are around 3300 to 3500, give or take. That's what I aim for with mine. When you know your salt levels are in range, you can calibrate to "Good" or solid green light (not flashing). Link for re-calibrating: ... %20cal.pdf
    Good luck, and feel free to ask as many questions here as you need to. I'm sure others will chime in. It's a great and knowledgeable group!
    7,000 gal. IG gunite, SWG, PebbleSheen interior finish-Aqua Blue, 8' vanishing edge raised 16-jet overspill spa, 2 12" waterfalls, tan shelf with bubbler.
    Pentair equipment: Easy Touch 8, Intellichlor IC-40, Intelliflo VF 3050, 2.5 hp Whisperflo spa pump, 1 hp Whisperflo water feature pump, Quad 100 DE filter, Master Temp 400 heater, Legend Platinum Cleaner (3/4 hp pump). Autofill, TF-100 Test Kit w/salt and borate strips.
    Pisces Pool Build
