Results 1 to 15 of 15
Thread: Hi and Been awhile have problem hoping you guys tell me it's no big deal.
    Mar 2016
    Orient, SD
    12
    as per my older post my pool at the time was not set up. well now it's up, Went to set up filter and ran pump and filter (was a proud moment for me) 20 min later I could of died. Filter has 6 very tiny stress fractures that I did not see when I was installing it. So needless to say hubby came home I was crying (yes I was so ) not a lot of money is sitting around and can buy new filter. So I pumped out water to small pool thank goodness I still had it up. Don't want to lose any more money at this point. I went to bed.
    While I was sleeping my beloved hubby does something I never thought he would do. he bought us a new filter and a used pump from a local guy he just droped it off this morning while I was at work.
    So no getting our money back on this. I have no idea what he paid he won't tell me Sorry getting off track
    it's a Jandy dual speed pump (used) I'm told it works just fine.
    And a New Hayward c3030.
    My question is both of these have 2" connections can I dial them down to 1 1/5" ??????????????
    Please someone give me some good news I don't have the heart to tell my hubby it's not going to work.
    Swim N Play 45' x 18' x 52" Oval
    Hayward c3030
    Hayward Max Flo Pump SP2302VSP
    38,262
    Re: Hi and Been awhile have problem hoping you guys tell me it's no big deal.
    ABSOLUTELY!!!! you can use PVC reducer fitting to attach to your 1.5" PVC plumbing.
    Sounds like the pump is a nice upgrade with the 2 speeds able to save money on power.
    Remember the new filter is now a cartridge and not a DE filter so the maintenance is a bit different.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,766
    You should be able to adapt the pvc from 2 inch down to 1.5inch. Check the filter tho it may be built to accept both sizes of fittings.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    lowes will have most everything you will need to connect your new pump and filter including pipe.. look at some of my install pictures below in my signature to get an idea of how to use hard pipe
    Mar 2016
    Orient, SD
    12
    OMG YOU GUYS ARE THE BEST!!!!!! I can't thank you guys enough!!! You all just made my night and my summer for my kids!!
    Hayward c3030
    38,262
    We are here if more questions pop up
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,521
    I bought a pair of these at Leslie's for $9 to hook up my aftermarket pump to my Intex pool. It was cheaper and easier than making my own from PVC from Lowe's.
    Amazon.com : GAME 4560 40mm to 1 1/2 Inch Conversion Kit (For Intex Garden
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Casey's Avatar
    SW PA
    10,427
    We're always here for ya.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,444
    Honey we got ya! Take a pic and we can even tell you how to do it.
    That was SO sweet of hubby.......he did not want to see your cry. Happy wife, happy life at it's finest!
    Kim
    Mar 2016
    Orient, SD
    12
    Hayward c3030
    mbuice's Avatar
    Jul 2014
    Denton, TX
    95
    So exciting, thanks for updating!
    18 X 34 AGP 7ft deep end, 22,300 gallons. 250lb sand filter, 2 speed 1.5 hp pump. TF-100 Test Kit.
    Jul 2012
    Tallahassee, FL
    30,444
    That pool is HUGE! How many gallons??
    Kim
    Mar 2016
    Orient, SD
    12
    Sorry been kinda busy. pool size according to my short knowledge is between 21k and 22k
    Hayward c3030
    Blake1989's Avatar
    May 2012
    Birmingham, Alabama
    135
    DANG that pool is ginormous! Perfect pump for that size pool!
    Above Ground 30' by 54" 22,600
    Hayward S244T Sand Filter w/ 1.5HP Dual Speed Hayward Powerflo Matrix Pump
    TF100 Test Kit
    BBB ALL the way!
    Questions about pool care? Visit Pool School
    Casey's Avatar
    SW PA
    10,427
    Daaaaaaaang.... When can we come over?!
