Thread: What about metals?
    JohnA902's Avatar
    Apr 2016
    Baltimore MD
    109
    Lightbulb What about metals?
    So far I'm completely focused on bleach, cya and acid and I'm crystal clear (my alkalinity and calcium hardness have been just fine in the first 4 days). However, I remember the pool company giving me some magic jacks stain remover and then I've seen some threads about iron and copper.
    I am using well water through a water softener system (ion exchange) and have been filling with a hose.
    How will metal issues present themselves, if I were to have a problem? Or a stain, I guess I would see that?
    just curious what to expect.
    John
    27,000 gal concrete rectangle, built Oct '15, DE filter, Jandy PHPM 1.5 HP, Hayward HP21104T heat pump, TF-100
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Re: What about metals?
    The most common metal from a well is iron. It will show up as brown water or stains in the plaster.
    More here, Pool School - Metals in the Water and Metal Stains
    JohnA902's Avatar
    Apr 2016
    Baltimore MD
    109
    Great thank you. Once I get more familiar and comfortable with the TFP process I'll have my softened well water tested for iron and consider a regular dose of a sequestrant if someone is high.
