Results 1 to 9 of 9
Thread: First pool opening
    May 2016
    Pennsylvania
    6
    First pool opening
    Hello all, we got our inground installed last year. First opening this year, cover comes off today and there are stains all around marking the outline of the cover. Scrubbing doesn't do a thing. I was told not to pressure wash by the place that opened it. Any thoughts on how to clean the marks? Thanks in advance.
    38,268
    Re: First pool opening
    Welcome to TFP!!!
    Where are the marks? in the pool? on the deck?
    Pictures?
    May 2016
    Pennsylvania
    6
    Sorry....on the concrete deck all around the perimeter of the pool.
    May 2016
    Pennsylvania
    6
    No pics yet...it's dark here now. Will take some on the morning and post. Basically looks like the outline of the cover all the way around the concrete deck.
    May 2016
    Pennsylvania
    6
    Quote Originally Posted by CluelessPoolGuy View Post
    Here are some pics....looks like rust or algae.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    50/50 muriatic acid / water and a scrub brush should clean that up easily.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,444
    I second what Mr. Bruce says! ^^^^^^^^^^
    Kim
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Those do look like they resemble metals staining, especially since they follow the line of the spring anchors. The dilute MA mixture should do the trick as Bruce advised. Rinse the area down well with a hose, away from the pool, after scrubbing.
    Isolated Spa - 345 Gallons
    May 2016
    Pennsylvania
    6
    Thanks all. I'll give that a try.
