Results 1 to 18 of 18
Thread: My numbers using my NEW TF-100!
    Jul 2007
    St. Louis
    19
    Hello, all!
    Just received my TF-100 kit. great kit and instructions, thanks!
    Water looks clear (don't know how it feels...68 degrees) Unfortunately, my numbers are very off and not sure what to do. Here ya go!
    FC 0
    CC 0
    TC 0
    pH 7.5
    T/A 320
    CH
    CYA 0
    Any help would be appreciated!
    Ben
    Vinyl IG, 16200G, Sand, SWG (Intellichlor), 3 deck jets and 2 laminar flow fountains from atop a retaining wall.
    30,431
    Re: My numbers using my NEW TF-100!
    Hi, Ben,
    1. You need CYA in your pool. Use Jason's calculator to bring your CYA to 60 or so. It'll take a few days to register on the test.
    2. For the next couple of evenings, I would suggest one large jug of clorox into the pool. It's sort of a "safety net" to keep algae at bay until your CYA becomes effective.
    As soon as you get a positive test for CYA. Adjust your SWG to keep 3-4ppm of chlorine in your pool all the time.
    3. I suspect the TA test is innaccurate. Try that test again and this time use a damp cloth to wipe the dropper ti[p every 2-3 drops. Static electricity develops in the R-0009 resulting in very small drops and throws of the test results. The damp cloth eliminates that error virtually every time. I'm thinking your new result will end up in the 100's.
    Jul 2007
    St. Louis
    19
    so just use some stabilizer, keep shocking and retest? I'll do that and retest, including the revised TA instructions, and repost tomorrow!
    Thanks.
    Ben
    Ben
    30,431
    Well, sort of. Please calculate enough stabilizer to get to 60 ppm in your pool. Use Jason's calc in my sig.
    "Keep shocking" has me just a little concerned. You are certainl;y not shocking with 0 FC. Nor will you be shocking by adding the Clorox I suggested. Shocking is a process using very large doses of chlorine to clear a pool of contaminants.
    I don't see anything in your test results that indicate the need to shock so I am suggesting getting stabilizer in your pool because you cannot hold FC without it and adding a little clorox until your stabilizer can take effect.
    Have you read the first few basic articles in Pool School?
    Jul 2007
    St. Louis
    19
    You were correct on the T/A. With new procedure, T/A is 140.
    I have added 87 oz. of stabilizer to my skimmer. As far as the Clorox- I have 12.5% liquid chlorinator titled 'Pro-Clor Pool Shock (hence me calling it 'shocking' the pool whenever I add any of this-sorry for the confusion). Will using half the amount of this have the same effect as a whole bottle of Chlorox? Please advise if I need to run out and actually get Chlorox or if this will do the trick. Will test again tomorrow and repost.
    Ben
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Quote Originally Posted by STLVinyl
    Yes, they are the same thing, liquid chlorine, your stuff is just twice the strength as Clorox. How many ounces are on the bottle? Is it a gallon jug? Clorox comes in 96 oz and 174 oz jugs. Use the Pool calculator to figure out how much to add, make sure you change the contentration in the box that has the % next to it, and then jug size. Calculate, and it will tell you how much to add.
    With the CYA in the skimmer, do not backwash your filter for one week, retest the CYA in about 4-5 days. After 48 hours, assume the CYA you added is the current level and adjust your minimum FC level according to the CYA chart. Hope that makes sense?
    11,969
    Use about 1/2 of your 12.5% jug of chlorine today, use the other half tomorrow. Hopefully by Tuesday you will see the FC holding as the CYA starts to work.
    Jul 2007
    St. Louis
    19
    Let's see if I have this right.
    -add another 1/2 bottle of my liquid chlorinator tomorrow (Mon)
    -recheck FC/pH daily
    -should notice some results from in FC by Tuesday
    -retest CYA Thursday.
    One more question: currently my salt level is very low (2500). should I add salt now, or would that just be a waste until my CYA has stabilized?
    Thanks again for all the great advice.
    Ben
    11,969
    You can add the salt anytime, but I wouldn't turn the SWG on until the CYA and salt levels are in range. Just stick with Liquid chlorine until your water is balanced.
    Use the pool calculator to know for sure how much to add. It may be 1/2 a jug, may be more, may be less. Test the FC level with the FAS-DPD test and then use the pool Calc to figure out your dosage. You want to have your FC at about 2-3 for now, by Tuesday you should assume the CYA is at 40 you want to target the FC at 3-5. The idea is to have it at about 5 for the start of the day so that by the end of the day you still have it at least at 3. You don't want it to drop below 3, get it?
    With an SWG you will need to have the CYA higher than 40....so next week I assume you'll be upping it some more? See the water balance for SWG article and the Recommended levels article- you will want your CYA at 70-80.
    Jul 2007
    St. Louis
    19
    got it. Happy Mother's Day 'fpMom'!
    Ben
    Jul 2007
    St. Louis
    19
    Here are new numbers just taken 4pm CST 5/11.
    FC 4.5
    CC 0
    TC 4.5
    pH 7.2
    T/A 120
    CYA 70
    I thought it looked much better today, so decided to take a full set of numbers. Great results! Anything I need to do to those? Otherwise, plan is to add salt (very low...2500).
    Thanks again TFP!
    Ben
    Ben
    Your FC level is fine if you are using the SWG. But if you haven't turned the SWG on yet, you should keep the FC level at 5 or higher.
    Jul 2007
    St. Louis
    19
    Today's #'s
    5/12
    FC 6
    CC .5
    TC 6.5
    pH 7.2
    I am getting a foam across the top of the pool. Water itself looks good and the numbers seem to be fine. Salt is showing a little low (3200). What is the foam?
    TIA.
    Ben
    Ben
    The most common source of foam is using the wrong kind of algaecide. It is also possible for large amounts of organic debris to cause foaming, though that is rare.
    Jul 2007
    St. Louis
    19
    I don't believe I'm using any algaecide. I've only used stabilizer, liquid chlorinator, and salt. Not much debris in the pool...have kept it clean with a robot quite frequently for the last couple of weeks.
    Ben
    Jul 2007
    St. Louis
    19
    new set of #'s...5/13
    FC 6
    CC .5
    TC 6.5
    pH 7.2
    T/A 130
    CYA 54
    Salt 2750 (I have put 160 lbs in this week)
    Still have the foaming on the surface. Any thoughts?
    Thanks.
    Ben
    Ben
    11,969
    The fountains - make sure they are off and increase the FC a bit with liquid chlorine to help break down whatever may be causing the foam.
    Jul 2007
    St. Louis
    19
    Done. Will repost new #'s tomorrow. Thanks again.
    Ben
