Results 1 to 8 of 8
Thread: New Pool, New Water, First Time Using TFP Method
    Feb 2016
    Roselle, IL
    39
    Recently installed a new pool and just finished filling it with water (Lake Michigan Tap Water). My initial readings were:
    FC-0.5
    CC-0.0
    pH-7.5
    TA-140
    CH-200
    CYA-0
    Added 12.5% CL to get up to FC= 2.0, then started with CYA. After about 80% of the recommended amount of stabilizer, I am now at:
    FC-2.0
    CC-0.0
    pH-7.2
    TA-140
    CH-200
    CYA-20
    Should I aerate to get PH back up a bit before try to finish the remaining stabilizer? I also need the PH to get up so I can work on TA at some point, but not too worried about that yet.
    13,200 GAL Aqua Leader Influence 54" AG | Heyward S244T Sand Filter (250 Lbs.) | 2-Speed Hayward Pump | RayPak 206 Cupro Nickel Natural Gas Heater | Hard Piped | Kontiki 2 Suction cleaner | TF-100 Test Kit w/ SpeedStir | 2016 Install | Chicago Suburbs
    Jun 2014
    15,255
    Re: New Pool, New Water, First Time Using TFP Method
    With your elevated TA, I suspect your pH will rise quickly on it's own. But since you have a heater we don't want to take any chances. Yes - aerate a bit to get it at least to about 7.4-7.5, then keep an eye on it for a day or two and go from there. Keep the FC at about 3-5, never below 2 though. You can add more stabilizer at any time.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    your doing great, you can point a return up to make ripples in the water or a waterfall of some type works, this will bring your PH up naturally and allow you to drop your TA, check this out Pool School - Lower Total Alkalinity
    I take it you put stabilizer in to bring your CYA to 30 already so go ahead and bring your FC to target level of 4 and keep it above 2 at all times
    I hope this helps
    Feb 2016
    Roselle, IL
    39
    Thanks everyone, will check back after some CL and aeration
    Feb 2016
    Roselle, IL
    39
    How long should aeration take to raise the PH. I got about 0.2 rise in 10 hours, is this about right or should it be faster/slower? I have the return jet pointed up at 45 degrees, I am sure if I had a fountain or some other aeration contraption that I have seen on this site it would be quicker right?
    Jun 2014
    15,255
    You're right. Just depends on the type and amount of aeration you can generate.
    Feb 2016
    Roselle, IL
    39
    How long after adding MA should I wait to take a new PH and TA reading?
    Jun 2014
    15,255
    With pump mixing real well, you should be good in about 15-20 minutes.
