Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: Welcome to the swamp!
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    483
    It's that time of year again! I'm debating spending some money on a "hard" loop-loc cover that will keep out rain and sunlight so the water doesn't look like this every time we open the pool.
    SLAM * Chlorine/CYA Chart * Pool Math * Pool School
    17.5k gal IG Fiberglass, Triton II TR60 Sand Filter, Jacuzzi Magum Force Pump 1.5 hp, 3/4 hp booster, Polaris 280, TF-100 Test Kit with Speed Stir
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Re: Welcome to the swamp!
    A cover won't do much more than keep debris out.
    If you follow the TFP methods and close/open early, more often than not, most have opened to blue water.
    Good looking area btw. I have grasses like that but they are about 2 feet in size, wow those are huge!
    Dolphin E10 Cleaning Robot.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    483
    LOL That's the way I feel.
    Aug 2014
    Northern IL
    4,615
    Did you just open? We recommend opening before the water hits 60 degrees. That's about when algae likes to pick up.
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    483
    Quote Originally Posted by MarianParoo View Post
    Yes, today. I'll start the SLAM soon after the pool guys get done with the opening stuff. Never heard the 60 degree recommendation before, I'll think about that for next year. And as far as the cover goes, I was told that a cover that doesn't allow rain or sun in will keep the water clear until you open. Is that false?
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    yes it's false.
    all it does is keep junk out of the pool.
    The reason most pools turn green is lack of chlorine when the water gets to 60
    then the algae starts.
    Now if you do get a ton of leaves every winter then a cover will help.
    organic matter sitting at the bottom won't be helping any when your ready to open.
    Aug 2014
    Northern IL
    4,615
    You want to wait to close after the water is below 60 also. Some people have used a solid tarp over their mesh covers to keep gunk out over the winter.
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    483
    One big problem with opening before the water hits 60 - large oak trees. Have to wait until they stop dropping those flower tassels.
    Jun 2014
    Rogers, AR
    428
    Quote Originally Posted by Razorhog View Post
    I have a mesh cover and always open to clear water. I bring my pool up to SLAM level for closing and when I open I still have chlorine. I close after Halloween and open the third week in March every year.
    16x32 IG rectangular 21,800k new vinyl liner 2014, Triton II TR 50 sand Filter, Pentair 3/4 hsp whisperflow pump, 3 returns, TF100 test kit w/speedstir. Maytronics s 300i robot.
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    483
    Floc is settling the junk in the water. Next step is to vacuum and start a SLAM.
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    483
    Here she is the next day after starting the SLAM.
    Got up this morning and passed the OCLT! Next up is a final vacuum, adding CYA, and fixing the spider gasket so I can backwash without re-seating it every time.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Looks like you only have a week or so to go. Still really cloudy, Don't stop now or the green meanie will rear it's ugly head!
    For sure post another pic once you get the stuff cleaned up from the bottom.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Great progress! Definitely keep going a few more days and you will have sparkling water.
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    483
    Quote Originally Posted by pooldv View Post
    I'm going to have to "puck it" a couple of days, going camping. But have no doubt, the SLAM will resume and pix will ensue.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    What is your CYA?
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    483
    Quote Originally Posted by pabeader View Post
    What is your CYA?
    0 right now, headed to the store to buy some. It's been cloudy here lately but the sun is definitely out today.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Good idea Don't forget to take into account the CYA that will come from the pucks...
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    483
    1.9 ppm from each
  20. Back To Top    #20
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    you got it!
