Results 1 to 8 of 8
Thread: Surprise chlorine liquid
    So went to open the pool this weekend and it seems the pool company left a pail out and the lid open on a mostly full 35# tub of 3" tablets all winter. And of course they are not individually wrapped.
    So I now have a large tub of very strong chlorine liquid I can not put in the pool as I do not want to to raise my CYA (already at 60).
    Proceeded to open pool but how the heck do I get rid of this stuff? The container is not seal-able. The off gas is pretty bad as it is.
    I am thinking of using a pond pump to fill the now empty chlorine bottles so I can at least seal it all up. Then let it set in the sun until it degrades? Other suggestions?
    Thanks
    Mar 2015
    Cantonment, FL (Pensacola Area)
    380
    Re: Surprise chlorine liquid
    Well, I doubt it will breed any skeeters
    Sorry to be non-helpful. I wonder how long it would take to dissipate and disolve. Driveway cleaner maybe?
    Scott
    15,000 Gallons vinyl in-ground screen enclosed, Hayward Eco-star SP3400VSP, Hayward Aqua Logic PL-Plus, Hayward T-15 Salt Cell, Hayward S244T Sand Filter, Polaris 380 with booster pump, Hayward heat pump HP50HA. K-2006 kit.
    JoyfulNoise's Avatar
    May 2015
    13,201
    You ABSOLUTELY DO NOT WANT TO SEAL IT UP! You will cause a dangerous build up of chlorine gas which can lead to an explosive release of liquid.
    Simply move the bucket away from the house and let the chlorine off gas on it own. Do not try to contain the vapors in any way or else you will create a hazard.
    Matt
    Sep 2013
    Charleston, SC
    537
    Also, check to see if your local municipality has a drop off location for pool chemicals. Here is the link to mine under automotive and other products Household Hazardous Waste Recycling (HHW) | Environmental Management Department
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
    May 2015
    13,201
    Quote Originally Posted by otter86753 View Post
    Good idea but I doubt any municipal drop off will take a bucket of fuming tablets nor are wet tablets safe to transport. Wet tablets will continue to fume chlorine gas until they dry out. This problem was caused by some idiot at the pool service company and they should be the ones to correct it in my opinion. I'd be on the phone spitting mad at them to clean up the mess.
    Matt
    Sep 2013
    Charleston, SC
    537
    As would I, but you can drop any pool chemical off at our place. It is worth a try at least.
    Yep some "feedback" will be provided to them but I like to prepare for the worse. The reality is they cant transport it either...if they did and did it poorly how much you wanna bet I get sued by the minimum wage worker they send out and gets himself gassed?
    I wasn't even thinking of pressure buildup and that is a great point. From that perspective the ONLY way to get rid of it is let it air out. No one is going to pickup an unsealed container without getting paid...a lot more than I am willing to spend.
    Thanks for the help.
    Sep 2013
    Charleston, SC
    537
    Of course not, which is why I said you could drop it off (after off gassing of course). I had to drop off lots of pool chemicals left by the previous owners.
