Thread: Question on the Pentair Intellitouch Control Panel
    May 2016
    Houston
    3
    Hi All,
    I am new to the forum and I have met a problem, probably sound silly. I have a pool with Pentair Intellitouch control panel. I accidentally flipped the circuit breaker in the house (Marked pool). After I flipped the breaker back, the intellitouch can't start neither pump/cleaner/etc. There are electricity to the control panel. I can see the Filter Pump indicator light on in the panel, but Pump won't start. There is a GFCI circuit next to the Panel. I reset it and the light is on. Everything else seems fine and it's just not able to start the pump.
    I wonder if anyone had the similar problem can help.
    Leo
    ps0303's Avatar
    Jul 2011
    FL
    3,703
    Re: Question on the Pentair Intellitouch Control Panel
    So if you press the "F" for filter pump button on the inside panel of the Intellitouch, the pump does not come on?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,537
    Try pushing the "Reset" button on the main panel.
    May 2016
    Houston
    3
    Quote Originally Posted by ps0303 View Post
    Right, it won't start. The F button light is on but pump doesn't start. The same to the cleaner pump or heater. The only thing response is the Acurator valve. If I press the "V" button, they will switch to the other direction. The filter pump indicator and SPA indicator are on but the pump won't start at all.
    Quote Originally Posted by Jimrahbe View Post
    Thanks, I tried "Reset" button already but has no luck. I remember this happen before a year ago. I had someone maintain the pool at that time. I don't recall he opened anything but it worked again after he finish the pool cleanup.
    May 2016
    Houston
    3
    Just want to share the experience. Turns out I didn't push the Pool Circuit Breaker on the Main Circuit Board to the End. Once I push it hard to the end and switch it back, all became good.
