Thread: New pool bottom?
    Jun 2008
    MOBILE, AL
    65
    New pool bottom?
    I currently have a 24' round above ground thats about 8 years old that has a few problems; I have decided instead of fixing it, I am going to buy a new resin 24 above ground pool. The problem I have had with my current pool is the bottom always seems to get divots and foot prints over time which catch dirt. I have been looking at the Gladon Perfect Pool bottom but they are so pricey. I was wondering if anyone has ever put down vinyl flooring / linoleum under the liner instead of one of these expensive kits. It seems to me that it would be about the same but instead of having seams every 5' I would only have one seam down the middle.
    Whats your thoughts?
    24' AG, 52" wall ,resin with 1Hp pentair pump with sand dollar sand filter. Hayward aquatrol salt generator
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: New pool bottom?
    I used good old hard foam from lowes No divots, feet prints, holes, lines, great bottom Shop Expanded Polystyrene Foam Board Insulation (Common: 0.75-in x 4-ft x 8-ft; Actual: 0.687-in x 3.875-ft x 7.875-ft) at Lowes.com
