Results 1 to 9 of 9
Thread: Eyeballs Stuck!!
    hellstorm2004's Avatar
    Jul 2015
    Richardson, Texas
    182
    Eyeballs Stuck!!
    Hello Everyone,
    I was trying to replace all of my old eyeball fittings. I was able to replace only one. All the others are pretty much jammed in. Any tips on how to remove them? Looked up youtube and all but could not find much info on this.
    Purex Titron FNS DE Filter 25000 gallons approx.
    Century A.O. Smith B855 56Y 2HP Motor. 40x25 (approx). Plaster surface.
    TFT-100 Test Kit.
    Rainbow Lifeguard 320.
    DX5+S Cleaner.
    Jun 2014
    15,189
    Re: Eyeballs Stuck!!
    In this case, it might be best to post a pic so we can see how those eyeballs are affixed to the wall. Some have different outer rings/fittings.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,105
    I use a rubber strap wrench to loosen the rings on mine when they get too tight. Maybe that would work for you?
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Have you tried a pipe strap? Be carefull though, I broke one whole fitting once.
    http://www.amazon.com/Ridgid-31340-2.../dp/B0016ZYJWS
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    Jul 2015
    Richardson, Texas
    182
    I want to remove the whole fitting. Let me go home post lunch and will post a pic. To be honest, all of them are different. Looks like they were replaced at different times, and the previous owner just replaced it with whatever was at hand.
    I will have to get one of the strap thingies!
    TFT-100 Test Kit.
    DX5+S Cleaner.
    BattleOfYakima's Avatar
    Apr 2016
    Central Florida
    1,522
    This thread covers similar situation and the were a lot of suggestions, but kitchen gripper for jars won! Posting a picture will help get even more specific suggestions.
    If I was effective, and your pool makes you smile, please make me smile and CLICK HERE to Become a TFP Supporter!
    Also, please make AmazonSmile donate to TFP by CLICKING HERE, at no cost to you!
    My Florida Pool: 20k IG plaster cart K-2006 | Washington State Pool I help with: 17k AG vinyl sand TF-100
    Apr 2016
    Central Florida
    1,522
    Were you successful? If not, we can help more
    Jul 2015
    Richardson, Texas
    182
    Eeek... due to work pressure, this one is on hold. Will do it this long weekend!
    TFT-100 Test Kit.
    DX5+S Cleaner.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Pipe Strap
    Divin Dave,
