Results 1 to 7 of 7
Thread: WTB water chemestry wise
    May 2016
    Paramus / New Jersey
    26
    Hello,
    Testing tonight. On a regular basis what chemicals do I need?
    I assume baking soda, bleach, liquid clorine and DE (I have a DE filter). What am I missing?
    Thank you in advance for your help!
    33,000 IG vinyl DE
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    577
    Re: WTB water chemestry wise
    Muriatic acid comes to mind.
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
    38,524
    Bleach and liquid chlorine are the same thing. Generally all you're going to need is bleach and de and maybe some muriatic acid. Although everything we add to the pool is based on reliable test results.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Bleach/liquid chlorine, Muriatic Acid, and DE are all you really need to buy now... Besides the test kit
    Borax and baking soda are only needed if your TA and PH need adjusting up, the MA will take them both down and that is all most everyone ever needs...
    May 2016
    26
    Hmm. Thank you! I will have to determine if it makes sense to just use bleach vs chlorine. Thanks for the info!
    33,000 IG vinyl DE
    38,524
    Use this to help find the best deal on the liquid chlorine / bleach:
    Liquid Chlorine Cost Calculator
    May 2016
    26
    Great link! Thank you!!
    33,000 IG vinyl DE
