Thread: Extruded Polystyrene Pool Base
    May 2015
    fairfield, nj
    19
    Hey everyone, i'm installing a 15x30 oval pool in New jersey. I have 1 inch thick Extruded Polystyrene sheets for the base. I compacted the direct base with a plate compactor level which was an 18 inch to 0 dig out to get the ground level. I am going to backfill the low side after installing the base and pool. I was thinking about adding a root barrier like a 18 mil plastic sheeting or tarp, used for under concrete slabs under the XPS sheets. Would this be a good idea under the XPS? Is there anything else i need to do for a good stable XPS base?
    Thanks in advance for all your input.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Extruded Polystyrene Pool Base
    1 thing that we almost never recommend is back filling, with that said if your using a plate compactor and done right by layers you may not have a problem, but it is still a possibility it could sink, that pool holds about 110,000 pounds of water I also dug down 2 inch on the south side and 24 inches on the north side and compacted screenings 2 inches deep, I still had settling... go figure
    I did not use any plastic sheeting or barrier but I have 0 trees and no grass what so ever under mine
    May 2015
    fairfield, nj
    19
    the back fill would be the overdig trench on the on the low side and not the base. Just wanted to make that clear thanks
