Thread: Help-Adding Calcium Increaser for my pool
    May 2016
    Washington, NJ
    14
    i was told i needed to add about 25lbs of calcium hardner to my pool this week and to do so over the span of a week about 5lbs a day. Do i really have to mix it with water in a bucket or can i dispense it directly around the perimeter of my pool? i dont feel comfortable mixing it with water
    thanks
    Mike
    21' Round Radiant Pool Buried, 10,000 gallons, Vinyl Liner AquaGuard AG100 Cartridge Filter, AquaGuard 1.0 HP SPL Pool Pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: Help-Adding Calcium Increaser for my pool
    Does this pool have a vinyl liner? If so, you don't need Calcium. There's no plaster to etch.
    May 2016
    Washington, NJ
    14
    yes it does, ok so i should just return it then?, thanks again
    Mike
